March 23, 2021, 14:45 |
Simulating a fan using a cylinder
Rep Power: 5 |
Hi All
I am simulating a fan that cools an electronic equipment inside a column. To simulate the fan On FLUENT, I have used a thin cylindrical geometry with fan boundary conditions from both sides of the cylinder. In the inlet it's "Fan Intake" and the outlet is "Fan Exhaust). I am not sure if someone could share his experience on the best way of modeling this. The purpose of my study is to see how the cooling is performed, it does not really matter to see the flow across the fan. Thanks a lot Last edited by Kaptene; March 29, 2021 at 12:46. |
March 23, 2021, 22:12 |
Rep Power: 5 |
Need help please
March 24, 2021, 04:10 |
Alex
Rep Power: 49 |
You are currently the only person who knows which software you are using. The "right" way to model a fan inside the computational domain strongly depends on that.
March 24, 2021, 23:55 |
Rep Power: 5 |
I am using Fluent Ansys
March 29, 2021, 12:47 |
Rep Power: 5 |
Any help is really appreciated
March 29, 2021, 13:38 |
Continuum
Rep Power: 17 |
I have done this. It is a simple and fast way to introduce recirulation into an interior domain. I would suppose you'd want some fan swirl. Plus you'd want some throughput. The way my software works allows me to add BC to any interior control surface. So if I draw mass out one surface, I can put it back in on a another surface (other side of the fan) for a net zero mass. For the swirl, you'd need to define the fan axis and compute omega.spin ^(r-r.axis.fan) to get the spin velocity set on the surface. You can break the fan surface into 4 quadrants for simplicity as I have done this too. You can patch 4 different swirl velocities without the above spin calculation. If I get some time, I will add a picture. Regards, |
March 29, 2021, 13:42 |
Nima
Rep Power: 12 |
Creating & Meshing 2D Planar Surface (for simulating 2D Centrifugal Fan) | Arrows | FLUENT | 0 | January 21, 2017 13:02 |
Simulating Fan in Ansys CFX | Cabi365 | CFX | 1 | November 4, 2016 13:20 |
Trouble modelling a jet fan | josee | OpenFOAM Pre-Processing | 0 | September 23, 2016 14:06 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 17:16 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
