How can chemical equations be coupled with fluent to simulate ionization of airflow? |
March 22, 2021, 06:39 |
mohammad reza
Rep Power: 12 |
In plasma actuators simulation, voltage discharge is added to the momentum equation usually in the form of a source term. What is the solution if we want to simulate hypersonic flow (such as the re-entry of a shuttle into the atmosphere) that the fluid is ionized by the flow regime or special flowfield which air is ionized by temperature?
March 22, 2021, 10:28 |
Lucky
Rep Power: 66 |
In plasma actuators and such there is an external source, the actuator!
For hypersonic flows, you don't need anything special. You just need the right equation of state for internal energy / enthalpy (aka give the right specific heat table). |
March 22, 2021, 10:43 |
mohammad reza
Rep Power: 12 |
thanks for your answer. can you give me more information? if you discharge of voltage in air or rise its temperature up, how could you find out how much of particles of the air is ionized?
Last edited by m.r.soufivand; March 22, 2021 at 10:46. Reason: It has wrong English Grammar |
March 22, 2021, 11:48 |
mohammad reza
Rep Power: 12 |
I guess its need to Navier-Stokes in the multitemperature approximation.
March 23, 2021, 01:00 |
Lucky
Rep Power: 66 |
If you discharge a voltage in air, you provide and convert electrical energy to internal energy.
In high speed flows, the gas heats up due to adiabatic compression. The temperature rises due to conversion of mechanical energy of the flow into internal energy. However, this energy is already accounted for in the total energy equation. If you care about the detailed chemical reactions that occur, then you need to add addition species transport equations for the relevant chemical compounds and then provide reaction rate equations. However, as far as the Navier-Stokes and Energy equation are concerned, you do nothing. Well technically you do modify the enthalpy to also be a function of each of the species mass fractions, but that is again just having the right enthalpy. |
March 23, 2021, 02:58 |
#6 | |
mohammad reza
Rep Power: 12 |
Best regards |
chemical reaction, hypersonic, ionized air, plasma flow, plasma modeling |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
How to give Two-way coupled and one-Way coupled at a time in fluent? | krishna.n | FLUENT | 0 | June 27, 2016 07:09 |
SOLVING MODIFIED FLUENT EQUATIONS IN SECOND ZONE | HAMIDREZA | FLUENT | 0 | March 4, 2009 06:32 |
How to simulate the fan driven by the airflow? | Jason | FLUENT | 2 | April 17, 2008 15:56 |
how to solve non-dimensional equations in fluent | warloque | FLUENT | 0 | December 20, 2005 19:19 |
