How to calculate the divergence of velocity
Like Tree1Likes
  • 1 Post By sbaffini
Old   March 14, 2021, 04:10
Post How to calculate the divergence of velocity
Wang Yanqing
Proxima is on a distinguished road
Hi, i want to get the divergence of velocity field, and i have calculated the gradient of velocity on tecplot. When using equation DuDx+DvDy+DwDz to get divergence i find it is not equal 0 in incompressible fluid. can Anyone help me?
Thank you!
Proxima is offline   Reply With Quote
Old   March 14, 2021, 04:35
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
There are a lot of possible reasons. Provide more details about the source of your velocity field. Consider that in a numerical code it is also possible that you do not satisfy exactly the div v =0 constraint. But if you want to assess, you must use the same discrete operators used in the code.
FMDenaro is offline   Reply With Quote
Old   March 14, 2021, 04:50
Wang Yanqing
I am using ansys fluent to do my sumulation, second order upwind discrete on v and p. div v equal 0.5,1 or even smaller in almost domain, but it equal 50 in somewhere.
Old   March 14, 2021, 05:26
What you have to do is the check in Fluent, computing the div v field in Tecplot without using the same scheme used in Fluent makes no sense.
First of all, you have to assess if Fluent provide the correct divergence-free field.
Old   March 14, 2021, 08:42
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Also, as Fluent uses the Rhie-Chow approach for colocated meshes, your divergence free field will also nees a pressure part.
Your best shot is directly exporting the mass fluxes on the faces.
arjun likes this.
sbaffini is offline   Reply With Quote
divergence in fluent
How can I calculate and plot time-average velocity in Transient Simulation? Islam Ramadan FLUENT 4 January 26, 2024 15:10
how to calculate water average velocity in free surface models hmasenger CFX 22 October 30, 2019 20:28
How to calculate the axial velocity dispersion in CFD-Post? mayj CFX 4 February 20, 2015 02:04
UDF source using divergence of velocity ajene Fluent UDF and Scheme Programming 0 November 2, 2014 15:09
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
