[LES] Negative drag coefficient in some iterations
Like Tree2Likes
  • 2 Post By sbaffini
Old   February 18, 2021, 04:14
Default [LES] Negative drag coefficient in some iterations
Moreza7 is on a distinguished road
I'm simulating an airfoil flow using LES. I export the drag and lift coefficient at every iteration, but in some iterations(for example 1 in every 20 iterations), the drag coefficient becomes negative while the average value is OK.
It oscillates from 0.0300 to -0.0150 and the average value is about 0.0200.
Why is this happening?
Moreza7 is offline   Reply With Quote
Old   February 18, 2021, 09:58
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
While I cannot know why this is happening to you, a negative drag coefficient just means a negative force in the wind direction, which means an actual thrust, so to speak.
This is not impossible, however, especially for limited amount of times in unsteady cases or for limited portions of some larger manufacts. On average, however, the whole manufact is expected to have positive drag.
Of course, besides this, there is the non negligible aspect regarding the very difficult nature of the numerical drag computation. Which means that the effect of numerical errors might be relevant if the computation is not performed carefully... and even more so in LES.
Moreza7 and aero_head like this.
sbaffini is offline   Reply With Quote
airfoil, drag, les
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 23:13
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
