Why water injection inside combustion chamber increasing temperature at the outlet?
Like Tree1Likes
  • 1 Post By aerosayan
Old   February 17, 2021, 20:07
Default Why water injection inside combustion chamber increasing temperature at the outlet?
Pritam Dey
johnleo is on a distinguished road
Hello good people!
I am doing simulation in a gas turbine combustor where I am directly injecting water droplets to reduce the overall temperature of the domain as well as the outlet temperature. But when I am using nonpremixed combustion model the maximum and the average temperature at the outlet is always increasing. But when using the EDM model it's decreasing accordingly. What can be the cause behind this behavior? If you can give me an idea it would be really helpful.
Thank you.
johnleo is offline   Reply With Quote
Old   February 18, 2021, 06:15
Sayan Bhattacharjee
aerosayan is on a distinguished road
Disclaimer : Not an expert.
If the water injection causes the combustion to move closer to the outlet, i.e by preventing proper combustion -> due to improper fuel atomization + evaporation -> due to reduction in combustion chamber temperature -> due to addition of cold water and the energy wasted in evaporating the cold water, the temperature at the outlet *may* increase.
My *beginner level* guess is that the fuel couldn't atomize + evaporate correctly in the combustion region, but caught on fire as the incomplete combustion products were leaving out of the combustion chamber.
Don't know if it's the case for you, but it's just a guess.
johnleo likes this.
aerosayan is offline   Reply With Quote
Old   February 18, 2021, 21:21
Pritam Dey
Thank you very much for suggesting the probable reasons. However, I am still confused why the EDM model not showing any increments like the nonpremixed model. Anyways, thanks again for the time.
combustion model, temperature difference, water injection
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Liquid Injection into Hot Gas Combustion Chamber scowaltho ANSYS 0 November 13, 2019 15:15
CFX CHT increased mass flow rate for water matters little for outlet air temperature dingsheng1206 CFX 7 December 4, 2013 21:04
[Other] How to define internal walls for injector inside a combustion chamber by OF2.1.1 with sandy13 OpenFOAM Meshing & Mesh Conversion 0 May 22, 2013 07:59
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
