Finite difference method for fourth order PDE |
Box
Rep Power: 5 ![]() |
How can I solve this initial boundary problem?
WhatsApp Image 2021-02-14 at 20.58.08.jpeg Are my approximations right? WhatsApp Image 2021-02-14 at 23.18.58.jpeg it's the nonlinear mathematical model of the dynamics of a rotating drill string compressed at both ends by the longitudinal force N(x3, t) u2 - displacement of the center of bending of the cross-section of the bar along the x2 axe due to bending E = 2.1e11 # Pa - Young's modulus rho = 7800 # kg/м3 - density v = 0.28 # Poisson's ratio d1 = 0.12 # м - drill string inner diameter d2 = 0.2 # м - external diameter A = 2.01e-2 # Column cross-sectional area Ix1 = PI / 64. * (d2 ** 4 - d1 ** 4) # Ring section moment of inertia Omega = 0.33 # drill string angular velocity C1 = 0.01 # constant determining the rate of deviation of the drill string axis from the initial position in the Ox2x3 plane at the initial moment time. Thank you in advance ![]() Last edited by BoxQwerty; February 15, 2021 at 23:37. |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
I don't know the physics described by this PDE, the problem is not only in a consistent discretization but also on the mathematical character of the equation. A second order in time PDE could be hyperbolic but I see also fourth order spatial terms. Central discretization in time and space is consistent but I don't know if it is also stable.
Then, also the BCs for this problem should be analysed. Have you some specific reference? |
Box
Material I have is all in Russian.
![]() In short, it's the nonlinear mathematical model of the dynamics of a rotating drill string compressed at both ends by the longitudinal force N(x3, t) u2 - displacement of the center of bending of the cross-section of the bar along the x2 axe due to bending E = 2.1e11 # Pa - Young's modulus rho = 7800 # kg/м3 - density v = 0.28 # Poisson's ratio d1 = 0.12 # м - drill string inner diameter d2 = 0.2 # м - external diameter A = 2.01e-2 # Column cross-sectional area Ix1 = PI / 64. * (d2 ** 4 - d1 ** 4) # Ring section moment of inertia Omega = 0.33 # drill string angular velocity C1 = 0.01 # constant determining the rate of deviation of the drill string axis from the initial position in the Ox2x3 plane at the initial moment time. |
Box
In short it's the nonlinear mathematical model of the dynamics of a rotating drill string compressed at both ends by the longitudinal force N(x3, t) u2 - displacement of the center of bending of the cross-section of the bar along the x2 axe due to bending E = 2.1e11 # Pa - Young's modulus rho = 7800 # kg/м3 - density v = 0.28 # Poisson's ratio d1 = 0.12 # м - drill string inner diameter d2 = 0.2 # м - external diameter A = 2.01e-2 # Column cross-sectional area Ix1 = PI / 64. * (d2 ** 4 - d1 ** 4) # Ring section moment of inertia Omega = 0.33 # drill string angular velocity C1 = 0.01 # constant determining the rate of deviation of the drill string axis from the initial position in the Ox2x3 plane at the initial moment time. |
finite difference, numerical solution, pde |
Finite element method ANSYS CFX | tomd97 | CFX | 2 | April 4, 2018 04:10 |
Finite difference method | kaliramesh | FLUENT | 1 | January 16, 2014 12:55 |
Difference between first order and second order | msatrustegui | FLUENT | 2 | December 5, 2012 05:54 |
Finite volume method vs finite difference method? | superfool | Main CFD Forum | 4 | October 21, 2006 14:37 |
High order compact finite difference schemes | Mikhail | Main CFD Forum | 6 | August 5, 2003 10:36 |
