What's the physical meaning of Q-Criterion? |
February 9, 2021, 13:12 |
Rep Power: 8 |
According to the definition, the Q-criterion defines vortices as areas where the vorticity magnitude is greater than the magnitude of the rate of strain. Why does Q-Criterion show the vortices? Why should Q>0 show a vortex? From a mathematical point of view, it's just a number! Also, suppose that we plot Q=10 and the Q=10000 what's the difference between the vortices with Q=10 and Q=10000? Thanks |
February 9, 2021, 14:04 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Have you already studied this paper? https://www.researchgate.net/publica..._JFM_285_69-94 |
February 9, 2021, 14:33 |
#3 | |
Rep Power: 8 |
The first question is answered now. But what about the second question? What's the difference between the vortices with Q=10 and Q=1000? I think when I plot the Q=10, the vortices with Q=1000 are also plotted. Also, sometimes I get the same structures with Q=10 and Q=1000! How can a vortex have two Qs?! It's confusing. |
February 9, 2021, 14:56 |
#4 | |
Rep Power: 73 |
The chosen value Q enters as a source term of the pressure equations, it defines the level of the pressure lines. That means you are considering different sources terms in the Poisson equation for the pressure. The vortex core is associated to minima in the pressure. Last edited by FMDenaro; February 9, 2021 at 16:26. |
February 9, 2021, 15:51 |
Kira
Rep Power: 9 |
Thank you Moreza for the question and thank you professor for the paper and the information! Helped me understand this concept better as well.
February 9, 2021, 16:39 |
Rep Power: 73 |
I suggest also this disseration
https://ntrs.nasa.gov/citations/19910017151 |
February 10, 2021, 06:57 |
EM
Rep Power: 7 |
the clearest flow interpretation (which still stands) of the (im)balance between the strain & vorticity terms in the poisson equation for the pressure, was originally proposed by Bradshaw&Koh in a short note that appeared in the phys of fluids of 1981. this is where u start. the later elaborations of this are computationally useful.
February 10, 2021, 13:06 |
#8 | |
Kira
Rep Power: 9 |
Do you have a link to this paper you refer to, or even just the full title? |
February 10, 2021, 21:46 |
#9 |
EM
Rep Power: 7 |
February 10, 2021, 22:07 |
#10 | |
Kira
Rep Power: 9 |
q criterion |
The physical meaning of Reynolds stresses? | Moreza7 | Main CFD Forum | 7 | January 29, 2021 06:52 |
Multiphase flow in cavity---B.C. doesn't correspond to physical meaning | linyanx | OpenFOAM Pre-Processing | 2 | December 14, 2016 18:17 |
[Gmsh] Nasa Nozzle: Plot 3D -->gmsh -->fluent - no physical groups | Nico89 | OpenFOAM Meshing & Mesh Conversion | 1 | June 14, 2016 06:40 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Physical meaning of pressure in pressure eqn | dontknow | Main CFD Forum | 2 | August 30, 2010 11:12 |
