"Mindcraft-like" grid ... what us it called?
Like Tree20Likes
  • 1 Post By sbaffini
  • 2 Post By aerosayan
  • 2 Post By Gerry Kan
  • 3 Post By andy_
  • 1 Post By andy_
  • 1 Post By andy_
  • 2 Post By andy_
Old   January 31, 2021, 18:24
Default "Mindcraft-like" grid ... what us it called?
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Howdy folks:
I am having trouble recalling the name for the type of meshing, where the geometry is discretized like objects in Mindcraft. I called it 'rasterized' grid, but is there another (i.e., official) name tor this?
Thanks in advance, Gerry.
Gerry Kan is offline   Reply With Quote
Old   January 31, 2021, 19:34
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I always used stairstep, but for some strange reason openfoamers use castellated... if I have understood correctly what you mean
Gerry Kan likes this.
sbaffini is offline   Reply With Quote
Old   February 1, 2021, 00:03
Sayan Bhattacharjee
aerosayan is on a distinguished road
voxel based grids
https://en.wikipedia.org/wiki/Voxel
PS : Also it's called "Minecraft".
There are a lot of videos and papers on the voxel tech used in Minecraft.
You can search for those terms.
Gerry Kan and aero_head like this.
aerosayan is offline   Reply With Quote
Old   February 1, 2021, 04:27
Gerry Kan's Avatar
Gerry Kan
Thanks Folks:
Now I have the chance to look it up, Ferziger and Peric used the term "stepwise approximation," but I guess "voxelation" gives the proper nuance in this case, as it implies fixed spacing (exactly like Minecraft).
Thanks again, Gerry.
sbaffini and aero_head like this.
Old   February 1, 2021, 08:49
Gerry Kan's Avatar
Gerry Kan
Originally Posted by sbaffini View Post
... for some strange reason openfoamers use castellated...
Paolo:
A side note on "castellate" ... I find it also strange, as the word came from "castello" or "castellum" (which I suspect you already know), and it has nothing to do with the topology of the mesh cells.
In this context, I suppose means to create fortification, i.e., building a castle,
or in the case of OpenFOAM, the action of packing very fine cells around the boundary of the solution domain during the early stages of snappyhexmesh.
Gerry.
Old   February 1, 2021, 08:54
sbaffini's Avatar
Paolo Lampitella
Originally Posted by Gerry Kan View Post
Paolo:
Gerry.
Thanks Gerry, good to know.
For some reason I kind of associated it to how outer castle walls appear at the top, if you know what I mean _|-|_|-|_|-|_|-|
aero_head likes this.
Old   February 1, 2021, 09:11
Gerry Kan's Avatar
Gerry Kan
_|-|_|-|_|-|_|-|
Paolo, ha ragione! I forgot that's also called a castellation! Gerry.
Old   February 1, 2021, 11:34
andy
andy_ is on a distinguished road
In the late 70s/early 80s in my company we used the term castellated for the version of the structured Cartesian grid CFD code that blocked out individual cells. Our terminals were Textronix 4010/14s and so we didn't use terms like pixels and voxels until later. The code development was shared with a group at Imperial College. The various CFD groups at IC largely shared techniques and terminology. Henry and co of OpenFOAM largely grew out of Gosman's CFD group in the Mech Eng. department. This may be why they use the older term but it is speculation on my part.
sbaffini, Gerry Kan and aero_head like this.
andy_ is offline   Reply With Quote
Old   February 1, 2021, 11:43
sbaffini's Avatar
Paolo Lampitella
Might be speculation, but the information seems quite spot on to me. Thanks
May I ask if that is a term that sounds more natural in the current English language with respect to, say, stairstep (which, indeed, sounds more natural in its italian translation)? Is there a difference with American English?
Old   February 1, 2021, 13:02
Gerry Kan's Avatar
Gerry Kan
Andy:
I didn't know is that Weller's Gosman lineage; I never really looked beyond quoting has paper for OpenFOAM, to be honest. In some way that means OpenFOAM has the same lineage as Star-CD.
Gerry.
Old   February 1, 2021, 13:12
andy
Stairstep is an American word not an English one. It is not a word I would ever use and, indeed, I had to look it up to check. Staircase is an English word for a flight of steps although simply stairs is perhaps more common. Castellate/castellation is still reasonably widely used English terminology but I suspect like many English words usage is declining. Don't know how widely used it is in America.
sbaffini likes this.
Old   February 1, 2021, 13:43
Gerry Kan's Avatar
Gerry Kan
To be honest (and as a self-appointed authority on American English*) I have never heard of "stairstep" to describe such a mesh before; this is why I asked the question for an official term in the first place. Nevertheless, it does contain the necessary imagery.
And for "castellate" I have only heard in conjunction in this context with OpenFOAM. I guess Andy put some historical note behind this, which was interesting to know. Otherwise I had to look it up for exact definition. In both variants of the English language it means either "to create a castle" (my definition from above discussion) or "to build battlements on existing walls" (Paolo's definition).
Gerry.
* - Modesty forbids.
Old   February 1, 2021, 15:02
andy
To some extent. Gosman himself developed within Spalding's CFD group at Imperial before forming his own. On the turbulence side he will have drawn on the work of Launder and students before he left IC after a major row with Spalding. The origins go back to the early 60s at IC and even further at Los Alamos which was probably the most active in the early days.
CD was David Gosman and Raad Issa's commercial venture based in Shepherd's Bush launched in the late 80s. The code would almost certainly not have been shared with their research activities at IC/Mines but the methodology would have been strongly correlated.
Henry and co were in David Gosman's group in the 90s. I presume this was FOAM but the group had become less forthcoming about what they were doing compared to earlier. I presumed Henry was a PhD student but might have been wrong since he doesn't seem to have written up. In truth I don't know what was going on within the group or the status of the software being developed. The commercialisation of FOAM via Nabla happened more than a decade after CD and well after STAR-CD had become a leading engineering CFD code particularly in the automotive field. I presume FOAM wasn't a success commercially hence the release of OpenFOAM.
Old   February 1, 2021, 16:14
Gerry Kan's Avatar
Gerry Kan
... before [Gosman] left IC after a major row with Spalding.
Andy:
Thanks for the background. Somehow you can substitute Gosman's name with any other and the sentence would still apply. RIP, Brian.
I remember dealing with a Nabla rep back in the early 2000s. However I haven't seriously worked with OpenFOAM until relatively recently. It has come a very long way, and the open source model has really worked for them.
Gerry.
Old   February 1, 2021, 16:28
Kira
aero_head is on a distinguished road
Andy:
Who is Brian?
Edit: Thanks to Andy for clearing that up below.
aero_head is offline   Reply With Quote
Old   February 1, 2021, 17:05
andy
I wrote it badly. Spalding had been misusing university facilities to support his commercial activities which was recognised by pretty much everyone in the department. Launder, a nice chap, eventually submitted an official complaint in order that something could start to be done about it. Then things turned very nasty. I don't know the details because it was before my time but Launder felt unable to continue in the department and left for the US (height of the brain drain) before returning to Manchester.
Brian Spalding was a smart but rather weird and untrustworthy individual. There are plenty of stories about him including a couple of my own encounters.
I dabbled once or twice in the early days but found it hard to get past the nonsense and gave up. I need to take another look.
In what way has the open source model worked for them? CD-Adapco was bought for $970 million and so I presume you are not referring to financially. The code likely has a lot of users because it is free but how many are valuable users in the sense of generating income or moving things forward? (I am asking not stating that they are few).
Old   February 1, 2021, 18:20
Gerry Kan's Avatar
Gerry Kan
Andy:
You didn't write badly. The nuance is exactly what I was referring to. Even though I personally have nothing to do with the person, product, or company, I have heard grapevines along that line, though not to the degree you described.
On OpenFOAM, the 'open' part has opened up a whole new cottage industry for people who provide their services as consultants and developers. While it costs nothing to use OpenFOAM, private companies pay relatively large sums for support and maintainence, not unlike other commercial codes. I personally know of large OEMs who have relatively large, dedicated in-house teams for OpenFOAM support and development. I cannot say if the original purveyors of this (ESI, OFF, and others) also bring in the same kind of money as ANSYS or Siemens, but their market share is, to say the least, not insignificant.
A colleague once told me, the difference between commercial codes, e.g. Star-CCM+ and OpenFOAM is like McDonalds and chop suey restaurants (or tikka masala, for folks from the Land of Hope and Glory).
Gerry.
Fluent LES model: grid requirement? dinhanh FLUENT 1 November 11, 2015 13:15
How to make grid for LES simulation dinhanh Main CFD Forum 3 November 11, 2015 03:37
Grid Adaptation Suresh FLUENT 0 October 15, 2003 14:18
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 09:32
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 23:26
