Why the pressure gradient is zero in laminar separation bubble?
Like Tree8Likes
  • 2 Post By aerosayan
  • 3 Post By FMDenaro
  • 2 Post By Gerry Kan
  • 1 Post By LuckyTran
Old   January 29, 2021, 14:34
Default Why the pressure gradient is zero in laminar separation bubble?
Moreza7 is on a distinguished road
I was reading some papers about laminar separation bubbles over the airfoils.
As you can see in the picture, the pressure coefficient is constant along with the separation bubble (the plateau part) :
Aslo the friction coefficient has the same behavior.
Is it because the flow is approximately static in that region?
Moreza7 is offline   Reply With Quote
Old   January 29, 2021, 14:47
Sayan Bhattacharjee
aerosayan is on a distinguished road
This paper ( https://www.longdom.org/open-access/...73.1000131.pdf ) states that the separation bubble is essentially a "dead air region" thus, this causes a sudden rise in Cp and since the flow is energetic enough, it reattaches downstream.
This is stated in the second paragraph.
I'm not an expert on the matter, you might want to consult others too.
Moreza7 and aero_head like this.
aerosayan is offline   Reply With Quote
Old   January 29, 2021, 14:54
Thank you.
I know the cause of the increase in pressure coefficient, but I don't know why the pressure coefficient is constant in separation bubble. I think it is related to dead air. Then what is the definition of dead air? Semi-static air, quasi-static air or what?
Old   January 30, 2021, 06:36
Sayan Bhattacharjee
Thank you.
Dead air probably means that the fluid stops moving at the original high velocity inside the separation bubble. I don't know if the fluid stops completely, but it might be approximately taken as a flow with zero velocity.
From the wikipedia ( https://en.wikipedia.org/wiki/Pressure_coefficient ) Cp = (p-p_inf) / (p0 - p_inf)
Since the flow is said to stop/stagnate inside the separation bubble, maybe p becomes approximately equal to p0? Since p0 is the stagnation pressure.
This would return a constant Cp value even if it's not exactly equal to 1.
Old   January 30, 2021, 06:55
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The discussion is about a constant Cp, but you cannot reach p=p0 (that would lead to Cp=1). In the bubble the viscous effects are relevant
Moreza7, aerosayan and aero_head like this.
FMDenaro is offline   Reply With Quote
Old   February 1, 2021, 13:15
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Dear Moreza:
If you think about this physically, when flow separates, it creates a low pressure wake region. Due to shear interaction between the freestream flow and the outer edge of this wake region, flow in this wake region must recirculate over time. This usually means the near-wall flow in the wake will be in the opposite direction than the near-wall flow outside the wake region. Your attached figure shows this.
We know that pressure gradient must be favorable (-ve) for the flow to travel in the same direction of the freestream, prior to the wake, and adverse inside the wake region. So there must exist a point where the pressure gradient is zero, and that is the start of the wake region, also known as the separation point.
The pressure coefficient is (more or less) constant in the wake region because the pressure gradient, albeit non-zero, is very small compared to the incoming flow. And this pressure rise in the region is very small compared to the pressure drop upstream.
Gerry.
Gerry Kan is offline   Reply With Quote
Old   February 1, 2021, 18:36
Lucky
When flow separates, it ignores the changes in the solid boundary and continues to advect along its initial trajectory. It maintains the characteristics of the flow at the point of separation and therefore continues along a constant Cp line. This is just an approximation/asymptotic behavior, there are still viscous effects and body forces at play for strong separation. You can sort of visualize this better if you replace the boundary of the separation bubble with a hypothetical solid wall, you would get the same flow field forgetting about the separation bubble.
aero_head likes this.
separation bubble
Laminar Separation Bubble and transition mrenergy FLUENT 2 June 12, 2023 09:50
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Polyhedral mesh cyclic boundary problem C-L OpenFOAM 13 December 21, 2016 08:53
SPH - Finding Pressure Gradient Anywhere sckulp Main CFD Forum 0 March 13, 2013 19:14
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
