[LES] Dynamic Smagorinsky coefficient: scalar or a tensor? |
January 24, 2021, 12:56 |
Rep Power: 8 |
First of all, Sorry if the question is amateur I'm am very noob in Einstien notation! As you know, SGS stresses tensor is . Also, Germano identity is a tensor . Then the coefficient of dynamic Smagorinsky is calculated by 2 tensors (with or without Lily's correction): While does not have an index, it seems that it's a scalar! I really don't understand how can it be possible that the divide of two tensors is a scalar! This means: (suppose for example we have a 2d case) My question is, why it is not calculated like this: Then we can have and which can be used in and momentum equations. |
January 24, 2021, 16:00 |
Filippo Maria Denaro
Rep Power: 73 |
The fact that the eddy viscosity is a scalar function or a tensor function depends on the chosen functional relation you use for the model. It is not a result of the Germano identity and the consequent contraction.
Indeed, there are anisotropic models in tensor form, see Sagaut. |
January 24, 2021, 16:26 |
#3 | |
Rep Power: 8 |
My question was a little mathematical: How can it be possible to divide two tensors and the result is a scalar? The numerator is the product of two tensors and the denomerator is the same. But the left hand side is a scalar. |
January 24, 2021, 16:43 |
Rep Power: 73 |
You have to consider the double scalar product between the two tensors, it is a scalar function
January 24, 2021, 18:31 |
Rep Power: 8 |
dynamic smagorinsky, les |
Creating a transient .case file | scro1022 | EnSight | 0 | November 27, 2020 11:11 |
[General] Problem with reading in multiple grouped Ensight .case files into paraview | scro1022 | ParaView | 0 | November 27, 2020 09:00 |
Updating the turbulent schmidt number in dynamic smagorinsky model | pvpnrao | OpenFOAM Running, Solving & CFD | 3 | November 6, 2020 04:52 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
