Passive scalar transport
Like Tree1Likes
  • 1 Post By FMDenaro
Old   January 18, 2021, 13:10
Default Passive scalar transport
Poimsm
Poimsm is on a distinguished road
what does it mean that a passive scalar will not vary alongside a streamline when the flow is incompressible?
Poimsm is offline   Reply With Quote
Old   January 18, 2021, 13:43
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I think you are a student learning the basic of fluid mechanics.
Consider the equation in a slight different form:
dpsi/dt+u.Grad psi = psi Div u
or introducing the Lagrangian derivative
Dpsi/Dt = psi Div u
for a divergence-free velocity field you see that Dpsi/Dt=0, that is the variable psi is constant along the path-line (trajectory) dx/dt=u. For steady flow (dpsi/dt=0) the trajectory coincides with the streamline, thus Psi is constant along the line having the velocity field tangent at each point.
This discussion can be applied directly to the continuity equation, that is the equation for the density. What textbooks are you reading?
aero_head likes this.
FMDenaro is offline   Reply With Quote
scalar
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 06:57
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 14:09
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
