Cohirn Projection Method
Like Tree1Likes
  • 1 Post By FMDenaro
Old   December 30, 2020, 20:58
Default Cohirn Projection Method
Moustafa
moustafa is on a distinguished road
Now I am coding a Matlab code to solve a flow inside channel using the Choirn projection method.
First thing I specified boundary conditions on each boundary from the four boundaries and specified the initial condition (the velocities in the domain)
FIRSTLY , I solved for intermediate velocity from Discretized Navier Stokes equation in the x direction(Finite difference method) with the pressure term dropped.
after this point I do not now to proceed , how to solve for the pressures and velocities at the next time step.
I want to know how to proceed as I am stuck at this point ?
and How to specify Boundary conditions for pressures ?
moustafa is offline   Reply With Quote
Old   December 31, 2020, 02:57
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
Never heard of the method CoHIRN projection. Do you mean Chorin's projection instead?
Regards
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Old   December 31, 2020, 04:16
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by moustafa View Post
Now I am coding a Matlab code to solve a flow inside channel using the Cohirn projection method.
What textbook are you reading? Do you have the original Chorin’s paper?
FMDenaro is offline   Reply With Quote
Old   January 2, 2021, 00:19
Moustafa
I am not using a textbook , I use research papers in order to understand
if you recommend a textbook that explain this method for undergraduate level , I will be so grateful
Old   January 2, 2021, 06:10
You can read Sec.7.2 here
https://www.springer.com/gp/book/9783319996912
and Sec. 12.4 in Charles Hirsch - Numerical Computation of Internal and External Flows. Elsevier 2007.
The original Chorin's method is described in his papers:
https://www.researchgate.net/publica...okes_Equations
be aware that there are decades of study and proposals about this method.
moustafa likes this.
fdm, projection method
Finite element method ANSYS CFX tomd97 CFX 2 April 4, 2018 05:10
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM keepfit OpenFOAM 4 January 31, 2014 15:32
Attempt to implement the Chorin Projection Method McFly OpenFOAM Programming & Development 0 October 26, 2013 07:46
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
Comparison: Finite Volume Method vs. Analytic Method m-fry Main CFD Forum 1 April 20, 2010 15:40
