Conjugate Heat Transfer B.C.
Like Tree1Likes
  • 1 Post By sbaffini
Old   December 24, 2020, 14:59
Default Conjugate Heat Transfer B.C.
SuperSonicCat is on a distinguished road
Hello forum,
i am currently trying to do a coupled cf-thermal- simulation:
I have a pipe with a hot water flowing inside. The pipe-wall is 2 mm thick and i am interested in the steady- state temperature-field in that wall. Which boundary condition should i apply on the outer wall of the pipe?
Lets say the pipe-wall is made of aluminium and the outer medium is air at some temperature.
How do engineers solve that kind of problems?
Best regards.
SuperSonicCat is offline   Reply With Quote
Old   December 25, 2020, 11:17
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Probably a convective boundary condition using an h from the closest possible case (buoyancy should certainly be accounted for).
SuperSonicCat likes this.
sbaffini is offline   Reply With Quote
Old   December 25, 2020, 13:03
Thank you!
I will try it out.
cfd, conjugate, heat, transfer
No conjugate heat transfer between solid (cast iron) and fluid (water) part Rajaero FLUENT 5 June 25, 2023 04:07
Conjugate Heat Transfer Gowrav FLUENT 0 October 10, 2018 06:55
No conjugate heat transfer between solid (cast iron) and fluid (water) Rajaero Main CFD Forum 1 August 23, 2018 14:01
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 11:44
conjugate heat transfer boundary condition Souviktor FLUENT 6 April 6, 2014 18:34
