fortran-c interoperable derived types
Like Tree4Likes
  • 1 Post By Eifoehn4
  • 1 Post By aerosayan
Old   December 20, 2020, 13:50
Default fortran-c interoperable derived types
Sayan Bhattacharjee
aerosayan is on a distinguished road
My most favorite feature in Modern Fortran is being able to store all of the arrays, matrices inside a derived type and sending all of that to a function/subroutine.
But I haven't been able to find a method by which I can store all of my matrices/arrays in a c struct, and send them to fortran. I consulted the book "Modern Fortran explained", and that says that allocateable arrays can't be inside fortran-c interoperable derived types.
Without this feature, we go back to subroutine calls that take 70 arguments, and fill up half of the screen.
In the interop-5-1 example code I wrote, I was able to store all of the array/matrix sizes inside the c struct, and send that to the Fortran subroutine as an argument. This would definitely allow us to package all of our Plain Old Data types like ints, doubles into the c struct, and reduce the number of arguments that need to be passed to the Fortran subroutines.
https://github.com/aerosayan/fortran-c-interop
In case the link goes down, here's the main.c
// AIM - Show how to pass a C struct to fortran
#include <stdio.h>
#include <stdlib.h>
struct blah
    int  len_array1; // We will use only one, but you could use all of them.
    int  len_array2;
    int  len_array3;
    int  len_array4;
void send_cstruct_to_fortran_(struct blah* s, int* array);
int main()
    // No. of elements in the array
    int n = 5;
    // Dynamic array
    int* array = (int*)malloc(n*sizeof(int));
    // Insert elements into dynamic array
    for(int i=0; i<n; ++i)
        array[i] = i;
    // Create object of struct
    struct blah s;
    // Store the first array length into struct
    // We don't care about the rest for now...
    s.len_array1 = n;
    // Send c struct to fortran, along with packaged data
    send_cstruct_to_fortran_(&s, array);
    // Scrub clean
    free(array);
    return 0;
In case the link goes down, here's the send.F90 code where the subroutine send_cstruct_to_fortran is present, and will be called from main.c
subroutine send_cstruct_to_fortran(cstruct, array)
    use iso_c_binding, only : c_int, c_ptr
    implicit none
    ! Fortran doesn't know how the c struct is defined, So, we use bind(c) to
    ! define a user defined type to match the c struct.
    type, bind(c) :: cstruct_interface
        integer(c_int) :: n1
        integer(c_int) :: n2
        integer(c_int) :: n3
        integer(c_int) :: n4
    end type
    ! The struct that has been passed from c to fortran
    type(cstruct_interface), intent(in) :: cstruct
    ! We're using the cstruct%n1 to define the array length, thus not needing
    ! to pass the size of every array/matrix/tensor with every function call.
    ! It's not perfect since we can't pass allocatable arrays inside structs.
    ! Thus, we have to pass them as subroutine/function arguments.
    integer(4), intent(in) :: array(cstruct%n1)
    print *, "- FORTRAN SUBROUTINE CALLED..."
    print *, "  '- SUBROUTINE :: SEND_CSTRUCT_TO_FORTRAN(CSTRUCT)"
    print *, "  '- CSTRUCT%N1        : ", cstruct%n1
    print *, "  '- ARRAY             : ", array
    print *, "- FORTRAN SUBROUTINE FINISHED..."
end subroutine
The output was :
   '- CSTRUCT%N1        :            5
   '- ARRAY             :            0           1           2           3           4
Using this method, I was only required to send in the array pointer and the rest of the Plain Old Data could be hidden inside the cstruct object.
This is a good step in the right direction, but we still have to pass all of the array/matrix pointers separately.
How can we send the array/matrix pointers to Fortran in a better way such that our subroutine calls won't require 70 arguments and fill up half of the screen?
Thanks
aerosayan is offline   Reply With Quote
Old   December 20, 2020, 15:51
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
You may write a parent C-wrapper routine with a clean struct object, which simply loops over all arrays in the C-struct. Here you can use your code to send each C-array (one after the other) to Fortran. In Fortran you also have a parent wrapper routine, which collects all Fortran arrays into a clean type object and outputs the result.
Just some thoughts.
aerosayan likes this.
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Old   December 20, 2020, 16:29
Sayan Bhattacharjee
Just some thoughts.
Hi Eifoehn4,
Thanks for the help.
Do you have any working example code for the technique you mentioned?
I never heard of such a technique, so I don't know how to implement it.
Thanks
Old   December 20, 2020, 16:43
Eifoehn4's Avatar
No not really. I don't think, there is an easy (intrinsic) workaround for this. However, i am quite sure it is possible to write a clean wrapper which does exactly what you want.
Regards
Old   December 20, 2020, 16:50
Sayan Bhattacharjee
Regards
If I understood you correctly, you meant to say that we could create a C function/subroutine that when called, will return the array/matrix that we want to access.
For example: If there are three matrices called flux, U, residual, we could write three unique wrapper functions called get_flux, get_U, get_residual to access those particular matrices from anywhere in our code.
Or if we don't want to make separate functions for separate matrices, we could create a single function like get_matrix(index_of_matrix), where we would access the particular matrix we want from an array in C, using the int index_of_matrix.
Is that right?
Regards
Old   December 21, 2020, 08:39
Sayan Bhattacharjee
Just some thoughts.
Hey E,
I implemented your idea. Man, was it difficult!
Thanks for the idea. I was able to get the pointers from C to Fortran, and store them inside a derived type. I also verified that the pointers are pointing to the correct data.
PROBLEM SOLVED!!!
To show gratitude for your help, let me share one cat picture and a meme as a reward. lol
Thanks
~Sayan
Code is in example interop-6-1 : https://github.com/aerosayan/fortran-c-interop/
In case the link goes down, here are the code.
main.c
// AIM - Show how to use memory allocated in c, for fortran allocatable arrays
//       Show how to package these allocatable arrays inside derived types.
#include <stdio.h>
#include <stdlib.h>
// We're using global variables to make the demostration simpler
int* array;
int* matrix;
// Call from fortran to get the array
int* get_array_from_c(){return array;}
// Call from fortran to get the matrix
int* get_matrix_from_c(){return matrix;}
// Call fortran subroutine and send our data
// If you notice carefully, we don't need to send the array and matrix
// by this method. We can define functions like get_array_from_c and
// get_matrix_from_c to get whatever data we need from c.
// If you notice more carefully, we don't need to define a separate function
// for separate arrays/matrices/tensors. We can store the array pointers in
// a long array, and use an integer index to access them.
// For example : flux_array = get_array(FLUX_ARRAY_INDEX);
// Where, FLUX_ARRAY_INDEX is an integer index,
// and get_array will be defined as get_array(int index){return data[index];}
void call_fortran_(int* array, int* matrix, int n);
int main()
    int n = 5;
    // Dynamic array
    // Dynamic matrix
    matrix = (int*)malloc(n*n*sizeof(int));
        array[i] = i;
    // Inser elements into dynamic matrix
    for(int i=0; i<n*n; ++i)
        matrix[i] = i;
    // Send array, matrix to fortran
    call_fortran_(array, matrix, n);
    // Scrub clean
    free(array);
    free(matrix);
    return 0;
send.F90
! We will package and encapsulate our data types inside a derived data type
! so that it can be sent to other fortran functions/subroutines along with
! the object of the derived type, and without needing to type many arguments
! for each function/subroutine.
module my_types
type data_container
    ! c_f_pointer expects a pointer to the arrays/matrices,
    ! so we have to define them as pointers.
    integer(4), pointer, dimension(:)   :: encapsulated_arr
    integer(4), pointer, dimension(:,:) :: encapsulated_mat
end type
end module
subroutine call_fortran(arr, mat, n)
    use iso_c_binding, only : c_int, c_ptr, c_f_pointer
    use my_types
    implicit none
    ! Interface to our c function that returns int* array
    interface
    function get_array_from_c() bind(c, name="get_array_from_c")
        import :: c_ptr
        type(c_ptr) :: get_array_from_c
    end function
    end interface
    ! Interface to our c function that returns int* matrix
    interface
    function get_matrix_from_c() bind(c, name="get_matrix_from_c")
        import :: c_ptr
        type(c_ptr) :: get_matrix_from_c
    end function
    end interface
    ! No. of elements in the array and no. of rows,columns in the matrix
    integer(c_int), value :: n
    ! Defining the array and matrix
    ! We will print the values, then call c_f_pointer to get the array & matrix
    ! from c, and then print them to verify the transfer. We will then modify
    ! the array and matrix received from c_f_pointer, then see if we the
    ! original array and matrix were modified.
    integer(c_int), intent(in) :: arr(n)
    integer(c_int), intent(in) :: mat(n,n)
    ! Derived data type to encapsulate our data
    type(data_container) :: dc
    print *, "  '- SUBROUTINE :: CALL_FORTRAN(ARR, MAT, N)"
    print *, "  '- N        : ", n
    print *, "  '- ARR      : ", arr
    print *, "  '- MAT(:,1) : ", mat(:,1)
    print *, "  '- MAT(:,N) : ", mat(:,N)
    print *, "- ENCAPSULATING DATA INSIDE DERIVED TYPE..."
    ! Use c_f_pointer to call get_array_from_c and store it inside
    ! the pointer dc%encapsulated_arr which has is a single dimension
    ! array of length n.
    call c_f_pointer(get_array_from_c(), dc%encapsulated_arr, [n])
    ! Do the same for the matrix
    call c_f_pointer(get_matrix_from_c(), dc%encapsulated_mat, [n,n])
    ! Print results to verify...
    print *, "  '- EARR     : ", dc%encapsulated_arr
    print *, "  '- EMAT(:,1): ", dc%encapsulated_mat(:,1)
    print *, "  '- EMAT(:,N): ", dc%encapsulated_mat(:,N)
    ! Modifying the arrays through the derived type
    print *, "- ADDING ONE TO EARR, EMAT THROUGH THE DERIVED TYPE..."
    print *, "  '- OPERATION :: dc%earr(:)   = dc%earr+1"
    dc%encapsulated_arr(:) = dc%encapsulated_arr+1
    print *, "  '- OPERATION :: dc%emat(:,:) = dc%emat+1"
    dc%encapsulated_mat(:,:) = dc%encapsulated_mat+1
    print *, "- VERIFYING IF ORIGINAL ARR, MAT WERE MODIFIED..."
end subroutine
output.txt
   '- N        :            5
   '- ARR      :            0           1           2           3           4
   '- MAT(:,1) :            0           1           2           3           4
   '- MAT(:,N) :           20          21          22          23          24
   '- N        :            5
   '- EARR     :            0           1           2           3           4
   '- EMAT(:,1):            0           1           2           3           4
   '- EMAT(:,N):           20          21          22          23          24
   '- ARR      :            1           2           3           4           5
   '- MAT(:,1) :            1           2           3           4           5
   '- MAT(:,N) :           21          22          23          24          25
Eifoehn4 likes this.
Old   December 21, 2020, 16:13
Sayan Bhattacharjee
Just some thoughts.
It's me again.
I found an infinitely better solution. Look at interop-5-2.
I can now send the arrays by packaging them directly inside the struct by defining them as type(c_ptr) and use them in fortran by using c_f_pointer. Now, I don't need any of that pesky function calls to get array pointers from C that I showed in interop-6-1. Now, we can pack everything inside the struct, and send that in to fortran. No need for function calls with 70 arguments.
Thanks
~Sayan
main.c
// AIM - Show how to pass a C struct to fortran.
//       Show how to pass a dynamic integer array from C to fortran using c struct.
#include <stdio.h>
#include <stdlib.h>
struct blah
    int  n;
    int* array;
void send_cstruct_to_fortran_(struct blah* s);
int main()
    int n = 5;
    // Dynamic array
        array[i] = i;
    struct blah s;
    s.n = n;
    s.array = array;
    send_cstruct_to_fortran_(&s);
    // Scrub clean
    free(array);
    return 0;
send.F90
subroutine send_cstruct_to_fortran(cstruct)
    implicit none
        integer(c_int) :: n
        type(c_ptr)    :: array
    end type
    ! We want to access cstruct%array.
    ! Thus we define array_local as a pointer to an array.
    ! We then use c_f_pointer to cast the c pointer cstruct%array to a
    ! fortran compatible pointer array_local. We can then use array_local
    integer(4), pointer, dimension(:) :: array_local
    call c_f_pointer(cstruct%array, array_local, [cstruct%n])
    print *, "  '- CSTRUCT%N    : ", cstruct%n
    print *, "  '- ARRAY_LOCAL  : ", array_local
end subroutine
output.txt
   '- CSTRUCT%N    :            5
   '- ARRAY_LOCAL  :            0           1           2           3           4
fortran, fortran-c/c++
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 06:37
CFD Code Conversion from Intel Fortran to GNU Fortran pitto Main CFD Forum 4 August 4, 2016 15:51
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
fortran derived type assignment Paolo Lampitella Main CFD Forum 1 September 12, 2008 05:53
Help: Reading values in derived types for VFortran Wee Main CFD Forum 0 October 15, 2006 10:39
