Basic question about local timestepping
Like Tree4Likes
  • 2 Post By flotus1
  • 2 Post By FMDenaro
Old   December 20, 2020, 06:50
Default Basic question about local timestepping
Sayan Bhattacharjee
aerosayan is on a distinguished road
This maybe a basic question, but I don't know the answer to it.
I was reading a code that does local timestepping in each cell to allegedly accelerate the solution convergence of a steady compressible Euler solver.
As shown in the picture attached, we can see the logic being used to calculate the minimum timestep possible for a cell, then updating the cell values with an m-stage process.
I don't understand how this actually works, and how the solution make any physical sense.
Based on the code, we can see that each cell will be advanced to different points in time, since every cell will have a different timestep calculated for it.
How does the simulation work when each cell is at a different point in time?
Thanks
Last edited by aerosayan; December 20, 2020 at 06:52. Reason: clarfication of question
aerosayan is offline   Reply With Quote
Old   December 20, 2020, 07:00
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The solution is only correct once the steady state is reached. I.e. the solution is fully converged.
sbaffini and aerosayan like this.
flotus1 is offline   Reply With Quote
Old   December 20, 2020, 07:13
Sayan Bhattacharjee
Okay, that seems correct. The simulations do work, and I've validated them before.
Thanks.
Old   December 20, 2020, 09:19
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thanks
The key to understand the issue is to forget about a physical meaning of the time step and considering only that the equations have a residual that is driven to zero by using local parameters for accelerating the convergence.
aerosayan and aero_head like this.
FMDenaro is offline   Reply With Quote
local time stepping, timestep
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
