Is pressure gradient normal to the wall zero?
Like Tree4Likes
  • 1 Post By FMDenaro
  • 2 Post By agd
Old   December 1, 2020, 11:28
Default Is pressure gradient normal to the wall zero?
Mandeep Shetty
granzer is on a distinguished road
I have read many posts dealing with the same subject but did not get a satisfactory answer. Is pressure gradient normal to the wall, zero?. Because if we consider an aerofoil then there is definitely a pressure gradient developing over the aerofoil wall. Also, I read that the pressure gradient within the boundary layer is zero and not outside the boundary layer. Is this correct?
granzer is offline   Reply With Quote
Old   December 1, 2020, 11:42
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by granzer View Post
I have read many dealing with the same subject but did not get a satisfactory answer. Is pressure gradient norma to the wall zero?. Because if we consider an aerofoil then there is definitely a pressure gradient developing over the aerofoil wall. Also, I read that the pressure gradient within the boundary layer is zero and not outside the boundary layer. Is this correct?
Not exactly, the NSE written at a wall will say you that dp/dn=ni*d^2u/dn^2. The BL approximation will drive you to consider dp/dn->0 for ni->0.
Thus, dp/dn =0 is a BL approximation accurate only at high Re numbers.
granzer likes this.
FMDenaro is offline   Reply With Quote
Old   December 1, 2020, 11:44
agd
agd is on a distinguished road
Is it true in general? No. But for a large number of flows it is a reasonable approximation. For attached flows over surfaces that possess small curvature it is a good approximation if other effects are not present. For example, if the surface is accelerating in the wall-normal direction, then the pressure gradient in the normal direction will not be zero. The best way to answer this question is to apply the NS equations at the surface in question under whatever physics you are dealing with and see what happens to the terms in the equations. See the development of the flat plate boundary layer equations for a good example of this.
granzer and aero_head like this.
agd is offline   Reply With Quote
Old   December 7, 2020, 16:24
Mandeep Shetty
sdasdas fa
Last edited by granzer; December 7, 2020 at 16:28. Reason: Tring to delete this message
Old   December 7, 2020, 16:27
Mandeep Shetty
I have seen the derivations and how the pressure gradient tends to zero as the wall-normal tends to zero. What I cannot fathom is how is it possible over an aerofoil as there is an obvious pressure gradient? Are we assuming the first layer of air molecules that is over the wing wall (and exerting the pressure over the wall) and the wall should be at the same pressure(every action from molecules has equal and opposite reaction from wall) ?. Are we also assuming that the pressure varies as the distance from the wall increases? So this gets modeld as "pressure gradient is zero between the wall and the first cell center above the wall"?
Old   December 7, 2020, 16:57
The BL theory for a flat plate should be extended with care to an airfoil. It should be considered in a local reference system in terms of the normal and tangential direction to the surface (see Schlichting). When the airfoil has curvature radius R>> delta you can assume the flat plate result dp/dy=0, provided the flow does not separate. Then, dp/dx in the theory is assumed to be a known term.
See also Sec.7 in Chap 10 of the Kundu textbook for the case of low R
granzer likes this.
Calculate wall normal gradient and store it in UDM mohibanwar Fluent UDF and Scheme Programming 0 September 15, 2020 02:24
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
Law of the wall in the presence of pressure gradient yidongxia Main CFD Forum 2 August 5, 2012 15:40
Velocity gradient normal to a wall ap FLUENT 0 July 26, 2004 09:32
