Using a laptop for CFD Simulations
Like Tree7Likes
  • 1 Post By flotus1
  • 1 Post By mushtak
  • 1 Post By aerosayan
  • 4 Post By flotus1
Old   October 31, 2020, 16:15
Default Using a laptop for CFD Simulations
Upeka
residual is on a distinguished road
I am thinking of buying a laptop for my personal use and want to know whether it is "okay" to run simulations for a day or two on a laptop?
I am thinking of buying a 16GB, Core i7 computer and would be simulating transient flows with mesh count ~1M. At the moment I am modeling transient flows of bluff bodies for varied operating conditions.
If it is very harmful to a laptop to run these simulations, I am thinking of buying a desktop with the same specs for a lower price. But since I am traveling back and forth from the university weekly, it would be very hard for me to carry a desktop.
residual is offline   Reply With Quote
Old   October 31, 2020, 16:32
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Running high CPU load for extended periods of time should not outright damage any laptop with a somewhat competent design. But some laptops can handle sustained load better than others. You will have to look at some reviews once you narrowed down your search to a few models.
residual likes this.
flotus1 is offline   Reply With Quote
Old   November 4, 2020, 04:46
ahmed
mushtak is on a distinguished road
To the best of my knowledge; you should not purchase the laptop for CFD simulations. It doesn't matter whether you will use 1m or 10m mesh cells. The thing which matter most is machine specifications. CPU's are slow enough to perform simulations whether it is attached with laptop or Desktop. GPU's are best option for CFD simulations. My suggestion is to purchase the Desktop workstation because even your simplest simulations will last 2-3 days so your laptop will heat up and stop working. Desktop can sustain that much pressure easily.
mushtak is offline   Reply With Quote
Old   November 4, 2020, 05:48
Sayan Bhattacharjee
aerosayan is on a distinguished road
May I suggest buying a powerful desktop to run at home, and when you're at college, connect to it through ssh if you're on linux/BSD, or remote desktop if you're on windows.
If the desktop is at home, you can simply ask your family members to switch it on/off when you need to use it.
aero_head likes this.
aerosayan is offline   Reply With Quote
Old   November 4, 2020, 05:57
flotus1's Avatar
Alex
Care to elaborate that point? It sounds like faster CPUs would be an issue
In the vast majority of cases, they are not. Either because the solver does not support GPU acceleration. Or because suitable GPUs cost a fortune. And of course, limited GPU memory.
No. Depending on what field you are in, you can have meaningful simulation results within minutes or even seconds.
Only the crappiest of laptops will do that. There are plenty of options that can handle sustained CPU load with no problem whatsoever.
Old   November 4, 2020, 06:04
Upeka
Thanks for the suggestion. I will consider that an option
Old   November 13, 2020, 20:34
Kira
aero_head is on a distinguished road
Short of setting up a server to run simulations, this is probably the best option to proceed with in your situation.
aero_head is offline   Reply With Quote
Old   March 23, 2023, 03:57
ait
Aly Taleb
ait is on a distinguished road
Have you considered using a cloud-based simulation tool. There's a couple of those around now
ait is offline   Reply With Quote
Old   March 23, 2023, 09:44
Josh Williams
joshwilliams is on a distinguished road
I have a good spec Microsoft Surface Book which I often run CFD + ML on (i7, 16GB RAM, 2 physical cores + hyperthreading). I do not often run it overnight, but there have been times I have done it no problem.
joshwilliams is offline   Reply With Quote
laptop, performance, transient flow, workstation
Fluent simulation in parallel is slower on workstation than laptop?!!?! losiola ANSYS 5 November 4, 2022 09:56
Confusion choosing between static / transient simulations TharunSK CFX 1 March 15, 2019 18:53
Laptop Recommendations FSAE_student Hardware 5 February 24, 2012 09:57
icem cfd ai environment 11.0, laptop keyboard problem, linux pertupd Hardware 3 October 3, 2011 09:27
Hardware selection for steady/unsteady incompressible, turbulent and cht simulations maddalena OpenFOAM 2 July 13, 2011 09:55
