Total Pressure vs Total Temperature
Like Tree1Likes
  • 1 Post By FMDenaro
Old   October 20, 2020, 17:01
Default Total Pressure vs Total Temperature
mardar
mardar572 is on a distinguished road
Why one is defined adiabatically and the other is defined reversibly?
Acarding to Anderson,
Definition of Total Temperature
Imagine that you grab hold of the fluid element and adiabatically slow it down to zero velocity. Clearly, you would expect (correctly) that the values of p, T , and ρ would change as the fluid element is brought to rest. In particular, the value of the temperature of the fluid element after it has been brought to rest adiabatically is defined as the total temperature, denoted by T0.
Definition of Total Pressure
Imagine that you grab hold of the fluid element and slow it down to zero velocity, but this time, let us slow it down both adiabatically and reversibly. That is, let us slow the fluid element down to zero velocity isentropically. When the fluid element is brought to rest isentropically, the resulting pressure and density are defined as the total pressure p0 and total density ρ0.
mardar572 is offline   Reply With Quote
Old   October 20, 2020, 17:27
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I suggest to understand these definitions by starting from the Crocco's theorem and then how the total pressure is defined from it driving to the Bernoulli integral.
Remember that T0 defines also the total enthalpy.
mardar572 likes this.
FMDenaro is online now   Reply With Quote
Old   October 21, 2020, 12:53
agd
agd is on a distinguished road
It goes back to the question of how much useful work you can get out of a system. If you consider the stagnation temperature first, the equivalent thermodynamic system would be a heat reservoir at temperature T0. Slowing the flow adiabatically is all that is required to reach the max temperature, since the lack of reversibility only shows up as an increase in the internal energy of the gas, and thus leads back to the temperature. For the total pressure, the equivalent thermodynamic system is a work reservoir, and the reversibilility condition means that the molecules are slowed down in a way that minimizes the appearance of energy in the gas in a mode that can't be extracted as work.
agd is offline   Reply With Quote
aerodynamic, pressure, temperature
Turbomachinery, transient flow - temperature limited and pressure AMG divergence dariuszkoz FLUENT 0 January 2, 2019 09:43
UDF for pressure outlet backflow total temperature MrDaimon FLUENT 13 June 23, 2017 01:45
Difference between total pressure, total pressure in Stn and in Rel frames turbo5 CFX 6 January 21, 2016 17:05
Difference between pressure, absolute pressure and Total Pressure shaswat CFX 1 September 6, 2012 07:12
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
