Meaning of the strain rate in non-premixed combustion
Like Tree1Likes
  • 1 Post By LuckyTran
Old   October 8, 2020, 16:49
Default Meaning of the strain rate in non-premixed combustion
q__
q
q__ is on a distinguished road
could you explain to me what is the interpretation of the so-called "strain rate" used in non-premixed combustion (not to be mistaken with the rate of strain tensor). In many textbooks the formal definition is simply a=dv/dy. But this applies only to simple 2d configuration of a counterflow. Is there a similar concept for 3d flow field?
Best Regards
q__ is offline   Reply With Quote
Old   October 8, 2020, 18:09
Lucky
Take the norm of the strain-rate tensor and you have the "strain rate"
dv/dy is technically a vector. You can see that even in the simple definition, the concept of magnitude/norm has already been utilized implicitly.
Old   October 8, 2020, 19:20
q__
q
Thank you for your interest.
By the magnitude do you mean the square root of the dyadic product of the strain rate tensor by itself?
Second question. I am not sure about that but I have already read about the concept of the principal directions along which the so-called principal "strain rates" act. So it appears to me that the concept of the "strain rate" is related to a particular direction and should have 3 components rather than single scalar magnitude in 3d case. Could you please comment on that?
Thank you.
Old   October 9, 2020, 04:03
Lucky
Yes, magnitude means square root of dyadic double dot product.
You can indeed decompose the strain rate tensor into two parts: one which is an isotropic expansion/compression and another which is the symmetric shear. Both of these each act in three orthogonal directions. But you still need to be careful whether you are talking about the strain rate tensor and its properties, or just the magnitude of the strain rate tensor.
q__ likes this.
combustion
gradient of strain rate magnitude for slip velocity totopo FLUENT 0 September 27, 2018 21:07
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 11:40
partially premixed combustion heat release rate per cell sqek FLUENT 0 May 16, 2017 09:04
Premixed Combustion nader1977 FLUENT 0 October 29, 2016 05:07
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 08:38
