Spalart Allmaras Turbulence Model: Compressible
Like Tree1Likes
  • 1 Post By sbaffini
Old   October 6, 2020, 03:19
Default Spalart Allmaras Turbulence Model: Compressible
anna
hasini is on a distinguished road
I'm reading into the Spalart Allmaras (SA) model to implement it in a solver, in its "standard" form without the trip term (see also the nice summary of the different versions on this NASA page: https://turbmodels.larc.nasa.gov/spalart.html#safv3 ).
What I'm wondering now: Spalart and co-authors have written in the paper "Modications and Clarications for the Implementation of the Spalart-Allmaras Turbulence Model" that the standard form of SA is also valid for compressible flows, even though the density does not appear in there.
Can someone explain me the reasoning behind this statement? Is it because we multiply the solved for nu_tilde with the density as kind of a post-processing to get the turbulent viscosity mu after we solved the transport equation?
Thanks!
hasini is offline   Reply With Quote
Old   October 7, 2020, 07:03
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
The reasoning behind it is common to several transport equations, which can either be written as rho Dphi/Dt (where D/Dt is the material derivative) or, by taking into account the mass conservation (Drho/Dt=0), D(rho phi)/Dt.
Basically, this is how equation 9 is built in the paper. For a finite volume code that is the form of the equation that you should prefer (besides some rearrangement of the non conservative term, which is discussed in both the Iaccarino thesis and the original SA references)
hasini likes this.
sbaffini is offline   Reply With Quote
compressibility, compressible, spalart allmaras, turbulence model
A problem about using the Spalart Allmaras model shiningkissss CFX 4 April 23, 2017 23:28
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Turbulent frequency equation for compressible kOmegaSST turbulence model (F1) Bojan OpenFOAM Programming & Development 1 September 1, 2013 13:20
2D Airfoil modeling using Spalart Allmaras Model mahbub03 Main CFD Forum 5 April 16, 2010 00:14
Spalart Allmaras Turbulence model - Need article! CFD Student Main CFD Forum 0 December 27, 2004 05:28
