calculating actual momentum thickness(theta) & Reynolds number based on it(Re_theta) |
September 21, 2020, 07:41 |
Jalal
Hi everyone!
I need to calculate momentum thickness (theta) and Reynolds number based on it (Re_theta) for a turbulent flow over a flat plate to capture the turbulent boundary layer. How to find the stream-wise location for a given Re_theta?? I do it as shown in attachment 1. After getting the required location, how do we calculate the actual momentum thickness? I do it as shown in attachment 2. Am I doing it right? Problem details: LES of turbulent flow over a Flat plate Flow is parallel to the plate Re (based on length of the plate) = 1 million Ma=0.3 Domain: shown in attachment named domain. The plate starts at x=0 Flow is in positive x direction. If further details are needed, please do tell me... Cheers!! |
flat plate analysis, les, momentum thickness, re_theta, turbulent boundary layer |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
