Comparison of Solvers
Like Tree1Likes
  • 1 Post By sbaffini
Old   August 16, 2020, 02:49
Post Comparison of Solvers
Ruchir Ravishankar
m15t3r_r0b0t is on a distinguished road
I am doing a comparison of various solvers in the transition regime with regard to the LSB separation, reattachment etc. - Fluent, OpenFOAM etc. using the Gamma-Re-Theta model. I created a mesh using Pointwise and plan to use it for all the solvers. I was wondering if I should use one mesh throughout all the solvers, or perform mesh independence for all solvers before moving ahead? Please help. Also, if someone could explain why I can do one and not the other, that would be amazing!
Thanks.
m15t3r_r0b0t is offline   Reply With Quote
Old   August 16, 2020, 05:41
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
That pretty much depends from what answers you want from your comparison.
Actually, you can do both.
sbaffini is offline   Reply With Quote
Old   August 16, 2020, 07:06
Ruchir Ravishankar
Thanks for replying. I want to compare the transition, separation and reattachment points, the length of the laminar separation bubble and Reynolds Stress contours. Finally, I want to draw a comparison on how much each software is under/over predicting the results as compared to wind tunnel data.
Old   August 17, 2020, 08:09
sbaffini's Avatar
Paolo Lampitella
I guess then that you want to do both. Pick up a common starting grid and a series of refinements stopping at the level where all the solvers are converged
aero_head likes this.
fluent, mesh, openfoam, pointwise, study
Solid Mechanics Solvers added to OpenFOAM Extend bigphil OpenFOAM Announcements from Other Sources 26 October 12, 2017 05:01
FSI solvers - best solvers steven123 OpenFOAM Running, Solving & CFD 0 July 8, 2014 11:26
comparison of discontinuity capturing by different solvers immortality OpenFOAM Running, Solving & CFD 1 May 17, 2013 15:39
Comparison of CFD solvers for Hydrodynamic problem furkan Main CFD Forum 0 August 22, 2006 12:00
comparison of CFD solvers Vivek V. Ranade Main CFD Forum 2 November 26, 2000 15:34
