The persistence (GLIBCXX_3.4.26 not found)
Like Tree2Likes
  • 2 Post By Hamza0
Old   July 23, 2020, 18:01
Post The persistence (GLIBCXX_3.4.26 not found)
Hamza
Hamza0 is on a distinguished road
Hi all,
When I tried to open paraview from the terminal after I run simulations from the tutorial package in OpenFoam I got the below message:
File "/usr/lib/command-not-found", line 28, in <module>
from CommandNotFound import CommandNotFound
File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 19, in <module>
from CommandNotFound.db.db import SqliteDatabase
File "/usr/lib/python3/dist-packages/CommandNotFound/db/db.py", line 5, in <module>
import apt_pkg
ImportError: /home/hayyash/OpenFOAM/ThirdParty-v2006/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0)
I did the necessary updates for libstdc++6 and other updates as well.
I am running OpenFoam under Windows 10 environment using Ubuntu 20.04 LTS.
Thank you for your support.
-Hamza
qutadah.r and tianfang_ccri like this.
Hamza0 is offline   Reply With Quote
Old   July 24, 2020, 08:07
Arjun
arjun will become famous soon enougharjun will become famous soon enough
This is happening due to the fact that someone in gnu compiler is forcing memcpy and memset to be used from newer versions of glibc.
Usually the program can use these from older versions too if the version from which code was compiled is not found in system. But someone had great idea to force them to be used from newer versions. This person has screwed things for many people around the world.
Now the solution I am not sure how you can do from the compiled code, but usually you can provide your own memcpy and memset and avoid the program to take it from system.
I did this when I deployed Wildkatze to some places since they did not have newer glibc.
Another way is if you yourself are compiling then to compile the code using older compiler.
arjun is offline   Reply With Quote
Old   July 24, 2020, 08:14
Default precompiled memcpy
Arjun
I attach you my libmemcpy and this is how i am linking it to wildkatze using cmake.
add_executable ( wildkatze janus/janus.cpp ${SOURCES} )
target_link_libraries ( wildkatze
${FVUSUser_LIBRARY}
${CMAKE_THREAD_LIBS_INIT}
/home/savya/FVUS5/wildcat/wGlib/libmemcpy-2.14.so
/usr/lib/x86_64-linux-gnu/libdl.so
Old   July 24, 2020, 15:37
Hamza
${FVUSUser_LIBRARY}
Thank you for the valuable information. I am a bit new of linux-like environment and will appreciate if you can break things down more.
-Hamza
Old   July 25, 2020, 11:48
Arjun
-Hamza
It was basically how I am connecting my own memcpy lib to my code so that it does not give me this glic warning. I am using cmake , a tool for compiling so for that you can also follow what i did and it shall be okay.
If you are not using cmake and compiling then you would have to find out how you can connect your own memcpy lib to it.
I posted to show you how you can do.
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 16:11
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
