dimitri koletsos
Rep Power: 6 ![]() |
Hi all,
From what I understand the Von Neumann stability analysis is used to assess the stability of finite difference schemes and the condition for conditionally stable schemes like the central differencing scheme (CDS) involves a critical timestep. I have two questions: 1. Can the Von Neumann analysis be used for finite volume analysis FVM and if so, would the analysis for CDS in FVM be identical to that of the finite difference method FDM? 2. How does a steady state simulation affect the condition regarding the timestep? Will a conditionally stable scheme be stable or unstable? Thank you in advance for your answer. Best regards, Dimitri |
#2 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
1) Yes, it applies to the resulting algebric system both for FD and FV methods. The results of the stability constraint depends on the resulting algebric system, that is not an issue of FV or FD scheme. 2) without time step (steady formulation) there is not stability analysis in the von Neumann sense. You have to see the constraint for the convergence of the iterative method. |
#3 | |
dimitri koletsos
I'm using the SIMPLE algorithm with the strongly implicit procedure (SIP) for the decomposition. I can only find that this method converges quickly, but not on how the central differencing might affect its stability. Last edited by dkoletsos; June 20, 2020 at 16:28. |
boundedness, central differencing, finite volume method, stability analysis |
Trying to understand FDM vs FVM vs Conservative form vs Non-conservative form | granzer | Main CFD Forum | 5 | December 4, 2019 03:00 |
Practical difference between FVM and LBM? | pharg_yrartibra | Main CFD Forum | 2 | November 25, 2013 10:52 |
FVM in 1-D spherical coordinates | lost.identity | Main CFD Forum | 0 | January 17, 2011 09:06 |
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM | kenn | Main CFD Forum | 2 | July 18, 2004 18:28 |
References for FVM | Anthony Wachs | Main CFD Forum | 8 | February 20, 2002 19:23 |
