June 16, 2020, 08:48 |
line plot
Rep Power: 6 |
do you know where this issue come from: Code:
--> FOAM Warning : From function void Foam::particle::locate(const vector&, const vector*, Foam::label, bool, const Foam::string&) in file particle/particle.C at line 483 Particle initialised with a location outside of the mesh when tracking from centre (-2.91666667 0.025 0.0208333333) of cell 0 to position (-2.91 0.025 0) --> FOAM Warning : From function void Foam::particle::locate(const vector&, const vector*, Foam::label, bool, const Foam::string&) in file particle/particle.C at line 483 Particle initialised with a location outside of the mesh when tracking from centre (-1.91666667 0.025 0.0208333333) of cell 6 to position (-1.91 0.025 0) --> FOAM Warning : From function void Foam::particle::locate(const vector&, const vector*, Foam::label, bool, const Foam::string&) in file particle/particle.C at line 483 Particle initialised with a location outside of the mesh when tracking from centre (-1.04166667 0.0125 0.0104166667) of cell 463 to position (-1.04 0.0125 0) Reading set description: wire1 wire2 wire3 wire4 wire5 |
June 18, 2020, 05:06 |
Ashwani
Rep Power: 13 |
You should ask this question in OpenFOAM Post-Processing Forum.
June 18, 2020, 21:00 |
Rep Power: 6 |
I did that now, thank you.
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
[Gmsh] No cells read from file ".msh" | hwsv07 | OpenFOAM Meshing & Mesh Conversion | 5 | August 13, 2018 16:42 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 12:37 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Meshing & Mesh Conversion | 3 | June 29, 2008 22:24 |
