Dilation of a differential fluid element in cylindrical coordinates
Like Tree2Likes
  • 1 Post By FMDenaro
  • 1 Post By tas38
Old   June 9, 2020, 19:49
Question Dilation of a differential fluid element in cylindrical coordinates
Emre
ordinary is on a distinguished road
Hello everyone,
I asked this question on Reddit but didn't get any solution.
I drew the image below to calculate volumetric dilation of a fluid element in cylindrical coordinates:
Then I wrote velocity components in terms of Taylor's series expansion:
After that I started to calculate dilation:
I'm missing something but I can't figure it out. Do you have any idea?
Regards,
Emre
ordinary is offline   Reply With Quote
Old   June 10, 2020, 04:15
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The volume dilatation is measured by the divergence of the velocity. You can write that in your reference system.
Or write the integral over your small volume and then take the averaging tending to a vanishing volume.
ordinary likes this.
FMDenaro is offline   Reply With Quote
Old   June 10, 2020, 10:21
Troy Snyder
tas38 is on a distinguished road
Originally Posted by ordinary View Post
Hello everyone,
Attachment 78274
Attachment 78275
Attachment 78276
Regards,
Emre
Your expression is correction except for a missing 1/r multiplying the circumferential velocity term.
Note also when comparing your derived result with the known divergence...
\frac{1}{r} \frac{\partial \left( r v_r\right)}{\partial r} =
\frac{v_r}{r} +
\frac{\partial v_r}{\partial r}
tas38 is offline   Reply With Quote
Old   June 10, 2020, 13:26
Emre
Thank you very much. I just wanted to prove it via different method.
Old   June 10, 2020, 13:37
Emre
\frac{v_r}{r} +
Thank you very much. So that means last definition of partial derivative Vr is correct. Only something is wrong with circumferential velocity term. I will check it.
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 9, 2019 00:50
Identifying Markers in a CGNS Mesh tjim SU2 3 October 12, 2018 02:21
Fluent calculating cylindrical coordinates Falldox FLUENT 1 January 31, 2017 11:10
Basic question about writing a differential equation related to finite element RbBb Main CFD Forum 1 April 10, 2014 04:50
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
