Basic question on scaling
Like Tree1Likes
  • 1 Post By tas38
Old   June 9, 2020, 16:08
Default Basic question on scaling
Peter
jomunkas is on a distinguished road
I have a very basic question. I have a fairly small airfoil around 5 cm. To calculate it's lift and drag I am using a solver in which the characteristic length is fixed to 1. Should I calculate the Re number like:
\rho*U*0.05/\mu
And run simulation with this Re, which will mean that the rho,U,mu numbers will change.
Or I should run simulations with \rho*U*1/\mu and then scale down the coefficients, but that means that the simulations are performed at a higher Re number then the real problem?
Kind Regards,
Jomunkas
jomunkas is offline   Reply With Quote
Old   June 10, 2020, 10:47
Troy Snyder
tas38 is on a distinguished road
Your goal should be to match the Reynolds numbers between the physical domain and the model. In this way you are striving for dynamic similitude.
jomunkas likes this.
tas38 is offline   Reply With Quote
Basic Fluent Statistics Question amanbearpig FLUENT 2 June 4, 2013 06:36
[Other] very basic question about createPhi.H feldy77 OpenFOAM Meshing & Mesh Conversion 2 November 22, 2011 09:16
Basic question on motorBike tutorial newToOpenFoam OpenFOAM Running, Solving & CFD 2 July 14, 2011 10:50
Basic Question Abhi FLUENT 1 August 4, 2007 09:07
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 20:01
