Why Prism Layers appear on inlet, outlet and symmetry planes? |
June 8, 2020, 13:20 |
MA
Rep Power: 6 |
I have generated a mesh using Surface Remesher/Polyhedral/Prism Layer Mesher in STARCCM+. I have defined the correct boundary conditions for inlet, outlet and symmetry planes in the regions, but I see that prism layers appear on these boundary types rather than wall-type boundaries. Why is that happening? After seeing this, I disabled the prism layer on inlet and outlet as for symmetry plane there is no any option to disable the prism layer, and then ran the surface remesher first and then volume mesher. But it didn't work. Again, I deleted the Regions and assigned the parts to regions, specified the BCs and ran the mesher, still the problem exists. Thanks for your time. |
June 8, 2020, 16:15 |
Lucky
Rep Power: 66 |
Are you using an automated mesh operation or a manual one in continua? The first doesn't recognize BC's because it's a predecessor in the pipeline.
June 8, 2020, 16:18 |
MA
Rep Power: 6 |
June 9, 2020, 01:59 |
Lucky
Rep Power: 66 |
Add custom controls and turn off prism layers on those surfaces. Do this in the automated mesher operation, not in region.
June 9, 2020, 05:15 |
MA
Rep Power: 6 |
June 9, 2020, 06:44 |
Lucky
Rep Power: 66 |
I doubt it. Post a pic of your tree.
Any BC's you apply are irrelevant to the automated mesher operation pipeline because it is a predecessor. If you use a prism layer mesher and do not use any custom surface controls, it will put prism layers on every surface because that's the default parent behavior. |
June 9, 2020, 08:27 |
Gerry Kan
Rep Power: 11 |
Dear Mazhar:
You need to manually disable prism cells on the boundaries that don't need them. Look for mesh setting under each boundary, and there you should be able to enable and disable prism cells for that boundary. On mine (it's old) its under: [Name of your region] > Boundaries > [Name of your Boundary] > Mesh conditions > Customize Prism Mesh In the Properties window (usually below your tree) you can choose among using default values, using custom values, or disabling it. Gerry. |
June 9, 2020, 09:04 |
MA
Rep Power: 6 |
Thanks for your kind inputs. I tried this all once it did not work so I deleted the regions and continua models. Assigned the parts to regions, specified boundary types, generated mesh, chose models and generated the mesh again now it works fine.
rhoSimpleFoam - Newbie Issues | AndyR | OpenFOAM Running, Solving & CFD | 6 | March 10, 2020 10:28 |
Issues with symmetry patches perpendicular to outlets | sturgeon | OpenFOAM Running, Solving & CFD | 2 | October 9, 2017 10:46 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
Channel with Symmetry planes | sona | OpenFOAM Running, Solving & CFD | 5 | February 7, 2013 19:33 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
