FDM oscillatory boundary condtions.
Like Tree1Likes
  • 1 Post By FMDenaro
Old   June 3, 2020, 15:35
Default FDM oscillatory boundary condtions.
Virendrasingh Pawar
DubsVeer23 is on a distinguished road
I couldn't find an FDM forum so I decided to post here. I am sure many of you can help me with my problem
It's 1-D heat diffusion with oscillatory boundary condition. A semi-infinite rod has it's one end heated: u(0,t) = sin(t) and the other end: u(L,t) is bounded.
The initial temperature profile is u(x,0) = 0.
I have to obtain temperature profiles at various times using (Euler) implicit FDM scheme.
The heat equation is: u_t = u_xx and the discretization is: u(n+1) = u(n,i) + (k/h^2)(u(n+1, i+1)-2u(n+1,i)+u(n+1,i-1))
I am struggling with the oscillatory boundary condition. Analytically, this condition introduces lag (e^(-x)*sin(t-phi)) in the rod, I can understand that but numerically how does one approach this situation (esp. the boundary condition) so that the analytical solution is well approximated.
Any help/suggestion is appreciated.
DubsVeer23 is offline   Reply With Quote
Old   June 3, 2020, 15:46
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
This is a homework and you can just see that the BC applies on the node i=1 (x=0) while you solve the equation at the inner node i=2 (x=h).
DubsVeer23 likes this.
FMDenaro is offline   Reply With Quote
Old   June 3, 2020, 16:22
Virendrasingh Pawar
Thanks. That is my approach actually but I am unable to approximate the analytical solution properly. Upon some reading, I understand that the temperature in the rod should lag the surface (boundary temperature), however, I am unable to fathom how a numerical scheme could achieve this. Can you expand your approach or suggest any reading? Thanks!
PS. It's an exercise problem in a book I am reading "Finite Difference Computing with PDEs"
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
