May 22, 2020, 17:17 |
how is TKE defined?
dimitri koletsos
Rep Power: 6 |
I understand that the turbulent kinetic energy is defined as k=1/2(<u_i*u_i>)
where does the factor of 1/2 come from? Is this pure convention? Has an integral been taken? Is there a more general equation, an averaging equation that brings in the factor 1/2? |
May 23, 2020, 07:01 |
Malte
Rep Power: 8 |
As a kinetic Energy is defined as 1/2 m c**2 , it makes sense to define the tke as 1/2sum(ui'ui'). i guess it would also make sense to multiply this with the fluid-density. wouldn't it? I was only working on incompressible turbulent flows so far. for me, it was pretty handy not to have the density in there
May 23, 2020, 08:00 |
There are several possible answers to this, but for all of them it really is a matter of convention. When you look at it from the fluid mechanics point of view, you really just need to look at it from the following perspective:
as the factor really comes out from differentiation. This is for the general kinetic energy. When you apply any average or filter to that, you end up with its turbulent counterpart that, obviously, has the same factor. From a more general perspective in mechanics, having the factor and the mass in the definition makes it an exact differential which is cool for some manipulations. |
turbulent kinetic energy |
User defined memory value changing | minhoabc | FLUENT | 2 | June 22, 2017 06:28 |
Not defined orientation change while running SU2_CFD | mdawson25 | SU2 | 4 | May 11, 2017 09:52 |
why CPtr_ defined as SlicedGeometricField, whereas magSfPtr_ as GeometricField? | Jerryfan | OpenFOAM Programming & Development | 1 | July 6, 2016 21:02 |
fetal overflow in user defined cavitation model | unclewallcn | CFX | 15 | January 20, 2016 22:17 |
definition of TKE and its relationship to buoyancy | winter | Main CFD Forum | 0 | December 10, 2007 16:34 |
