getting too high aerodynamics coefficients for NACA747A315 |
Prashant Singh
Rep Power: 6 ![]() |
Please help...
I used ICEMCFD for geometry creation and meshing of NACA747A315 with 120 mm chord length. The model was simulated using Fluent with inlet air velocity 75 m/s and 10 degree AOA. But the lift and drag coefficients came to be very high ( 780 and 65 respectively). Please refer the attached screenshots. |
duri
Rep Power: 17 ![]() |
User correct reference values for coefficient calculation.
Prashant Singh
duri
Can you put the screen shot of reference value panel
Prashant Singh
here is the screenshot of reference values.
duri
Reference values are correct. It means the forces are too high if the convergence and velocity field is fine then some thing could be wrong in units or mesh scaling.
fluent, icemcfd, lift and drag calculation |
high rotational speed centrifugal pump | marekpl | CFX | 43 | April 25, 2022 18:41 |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 12:29 |
[Other] Explain about the coefficients in the kOmegaSSTLM turbulence Model | ht2017 | OpenFOAM Community Contributions | 2 | April 23, 2020 03:55 |
Antoine Equation coefficients for water | Ludwig Prandtl | CFX | 2 | June 27, 2017 23:24 |
Getting too high Drag Coefficients | nicolarre | OpenFOAM Running, Solving & CFD | 10 | August 10, 2014 11:55 |
