k-w SST and Wall functions: How many layers? (Automotive aerodynamics)
Like Tree1Likes
  • 1 Post By LuckyTran
Old   April 17, 2020, 11:21
Default k-w SST and Wall functions: How many layers? (Automotive aerodynamics)
Andrea Stedile
steddy is on a distinguished road
Greetings,
I am using the OpenFOAM CFD suite to study the aerodynamic forces that act on a vehicle (more precisely, an Ahmed body).
I chose the k-w SST model, with wall functions boundary conditions.
I am still a beginner, and unfortunately I have no background in CFD. Right now, I am able to create some simple but fine meshes (with some millions of cells). I taught myself how to add layers on the vehicle's surface mesh and check the y+ values after the solver has run. I usually reach ~ 98 / 99 % of layer thickness.
However, I do not understand: How many layers should the vehicle's surface have? I noticed that y+ somewhat depends on the size of the first layer.
On the Internet, I saw that, when using Wall functions, y+ should be between 30 and 200 (or 30 and 300); whereas, when using a "full resolution" approach, y+ should be <= 1.
I also saw that, with the full resolution approach, the required number of layers should be 10, 20, or even more.
In my case, I am using wall functions, but I did not find a resource that points out the required number of layers. Do you have any idea?
If this can help, the motorbike tutorial in OpenFOAM, which uses the same model and wall functions, uses just 1 layer.
steddy is offline   Reply With Quote
Old   April 17, 2020, 18:01
Lucky
It's like asking how many cells you should have in your mesh. The answer is, however many you need to get the answer that you need. That is, we can't tell you unless you have an objective in mind. Even still, there aren't hard rules.
Some people need to capture all the boundary layer development in their models and so they pack the boundary layer full of cells. You can do this with layers or you can even do it with regular cells.
Some people don't care about the boundary layers. They might use very few layers just to have a nice mesh near surfaces so that you don't end up with velocity vectors pointing into walls. Some people don't even about this and will use no layers.
Some people are just doing CFD for funsies, just for the colors and don't do any postprocessing, none of these settings matter for them.
The scientific method applies. If you think it might change something, try it and find out.
mazhar16823 likes this.
Old   April 22, 2020, 14:42
duri
duri is on a distinguished road
Originally Posted by steddy View Post
Greetings,
In wall integration number of layers implies number of layers in viscous sub laminar usually y+ < 4. But in case of wall function no. of layers is not defined. The first cell should be in valid log law region typically y+ 30 to 200. It doesn't matter how many cells you have in log law region because shear stress is calculated from the log law and not from velocity gradient.
duri is offline   Reply With Quote
aerodynamics, automotive, layers, mesh, wallfunction
One more time: wall functions - SST CellZone OpenFOAM Pre-Processing 22 June 11, 2021 14:27
turn off wall functions in Transition SST model? johnp FLUENT 11 May 26, 2020 14:57
K-omega SST Wall functions ajmwtt FLUENT 9 March 26, 2019 10:39
k-Omega SST - Wall functions in OF 2.3 shereez234 OpenFOAM Running, Solving & CFD 4 November 12, 2015 03:54
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
