MATLAB problem
Like Tree1Likes
  • 1 Post By praveen
Old   March 13, 2020, 23:33
Default MATLAB problem
AeroSonic's Avatar
Yusuf Elbadry
AeroSonic is on a distinguished road
Hi guys,
I have a problem with MATLAB, I am writing a compressible NV solver Using FEM (GLS), everything is fine, but I have a problem with the running time.
the running time for a one-time step ( using 90x30 grid ) is 22 seconds, 19 seconds of them are wasted in one line which is the inverse of the global matrix.
you can find Matlab code analyzer in attachments, I really don't know why this line takes this much time ?!!
I tried different MATLAB Versions ( 15b, 17b ) but it taking more time than the current ( 18b ).
I am going to change the code to FORTRAN soon but currently, I want to know the reason for this problem.
My specs:
1- Ryzen 5 2600.
2- Ram 3000 MHZ 2x8 Gb.
3- SSD
AeroSonic is offline   Reply With Quote
Old   March 13, 2020, 23:53
Praveen. C
praveen is on a distinguished road
Matlab is slow if you use loops. If you cast everything as matrix-vector operations it can do better.
For CFD, Matlab is not so great, ok for some initial learning, but you soon reach its limitations.
Do you have to assemble your matrices every time step ?
You are using a direct solver and it has to do a LU decomposition every time.
If matrix does not change you can perhaps optimise, perform LU decomposition once,
https://www.mathworks.com/help/matlab/ref/lu.html
and reuse it.
praveen is offline   Reply With Quote
Old   March 14, 2020, 00:08
AeroSonic's Avatar
Yusuf Elbadry
and reuse it.
I am going to learn Fortran soon but.
as this is a compressible viscous and unsteady, yes i am constructing the matrices each time step and they are changing from element to element.
every time step, the code does the inverse line. I am using the mldivide.
Old   March 14, 2020, 00:37
Praveen. C
In your case, most time is taken in solve phase. Your matrix is not that big so the direct solvers should be fine. Maybe this is normal. The solve phase will be the most expensive in such a method.
AeroSonic likes this.
Old   March 14, 2020, 04:53
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Could you show a sketch at a couple of time steps of the sparsity of the matrix?
However, in any CFD code a solver for algebric system takes the most part of computational time.
FMDenaro is offline   Reply With Quote
Old   March 15, 2020, 18:00
AeroSonic's Avatar
Yusuf Elbadry
It was a problem in matlab, I have an AMD processor and matlab isnt configured for it, someone helped me
https://www.mathworks.com/matlabcent...#answer_401963
I am new to Cfd. Please help to develop a MATLAB for this problem Priyanka Konakandla Main CFD Forum 7 April 25, 2016 10:02
Please help me to develop a MATLAB code for this problem Priyanka Konakandla Main CFD Forum 0 April 23, 2016 06:35
Solving almost-degenerate linear problem? jollage Main CFD Forum 1 April 7, 2016 12:13
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
