Heat flux boundary condition
Like Tree1Likes
  • 1 Post By FMDenaro
Old   March 1, 2020, 02:03
Default Heat flux boundary condition
Mike_star is on a distinguished road
Hello everyone,
I am simulating airflow in a room with a block heater using a CFD code.
Does anyone know how to implement heat flux B.C of the block heater in a finite difference CFD code? In energy equation (I mean temperature transport equation), temperature B.C. can be easily applied to the code however applying heat flux B.C. is a little tricky. Can I use T(i)=q''/h+T(i-1) to implement the boundary condition in the fluid domain (T(i) is the temperature on the surface of the heater and shall be computed, T(i-1) is the temperature of adjacent node within the fluid)? If yes, how can I determine the h coefficient?
Any help or comment is appropriated.
Mike
Mike_star is offline   Reply With Quote
Old   March 1, 2020, 04:52
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Mike_star View Post
Hello everyone,
Mike
On a boundary (for example a wall) you set the continuity between the conduction in the solid (flux q) and the heat flux in the fluid (-k Grad T) along the normal to the boundary. That is
-k dT/dn = q
you see that q must be known from the physics of your problem and k is known from the fluid. Then, you have to discretize dT/dn using an asymmetric FD formula (I strongly suggest to use at least a second order formula) that gives the T at the wall as a function of the internal layer and the condition q.
FMDenaro is offline   Reply With Quote
Old   March 1, 2020, 05:03
-k dT/dn = q
Thank you for your reply. I think -k dT/dn = q equation is only applicable in solid domain where the heat conduction is dominant. However, this equation cannot be used for the fluid domain where both convection and conduction exist.
As I mentioned for obtaining the wall temperature, q=h(delta T) equation can be used. However the convection heat transfer coefficient (h) is unknown and that's my problem.
Old   March 1, 2020, 05:32
No, that depends on the problem you are considering. If you are studying a CHT problem then yes, the temperature field in fluid and solid must be solved together.
Conversely, in a classical heat transfer study the heat flux q applied at a wall is a known condition, that is you do not need at all to prescribe h but only the flux. This is a classical non homogenous Neumann condition that is expressed only in terms of the normal derivative of the temperature on the boundary.
pcosta likes this.
Old   March 2, 2020, 17:04
Pedro Costa
pcosta is on a distinguished road
Hello everyone,
Mike
Since you are doing CFD, it doesn't make sense to lump convective effects into a heat transfer coefficient h. You are already resolving convective effects from 'first-principles' in the CFD code, since you solve for a velocity field!
So, for instance, if you use central finite differences, at the boundary i=0 you could have something like: (T(1)-t(0))/dx = q'' -> T(0) = q''dx+T(1). But this BC is not centered at the boundary, so it may be nicer to use second-order one-sided differences as suggested above, and you have for constant grid spacing:T(0) = (-2*q''dx+4*T(1)-T(2))/3 [google is your friend for confirming this result ].
I hope this helps!
pcosta is offline   Reply With Quote
cfd, finite difference, heat flux
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
