Is there such a thing as "method" independence?
Like Tree2Likes
  • 2 Post By vesp
Old   February 14, 2020, 15:06
Default Is there such a thing as "method" independence?
Raphael
arkie87 is on a distinguished road
I read somewhere that someone was claiming that you can have a mesh independent solution for some flow problem using the first order upwind scheme, but that it might still be giving a wrong result, because it was not "method" independent i.e. discretization scheme independent. Accordingly, this person claims that if you repeated a mesh independence using second order upwind scheme, you would get a different value at mesh convergence.
Is this true, and if so, how can first order upwind scheme provide mesh independent value that is still incorrect?
arkie87 is offline   Reply With Quote
Old   February 14, 2020, 16:10
vesp is on a distinguished road
If the numerical scheme is consistent, its solution converges to the solution of the PDE for h->0. A first order scheme will likely nerd a finer mesh than thesecond order one, but both will converge to thesame solution (for smooth problems!) or one has a bug.
FMDenaro and pcosta like this.
vesp is offline   Reply With Quote
Old   February 14, 2020, 16:13
Raphael
That is my understanding too....
Old   February 14, 2020, 16:17
Raphael
What do you mean by "smooth problems?"
Are you talking about discontinuities that would cause false diffusion to become significant, because mesh independence study should take care of that.
If you are talking about discontinuities causing second order scheme to cause overshoots and undershoots and be worse than first order, then yes, that makes sense too.
Old   February 14, 2020, 16:39
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
As addressed above, the Lax equivalence theorem ensures that a liner scheme that is consistent and stable converges towards the solution of the PDE, no matter about first, second or higher order of accuracy.
Maybe the issue is discussed in the framework of non linear problems?
FMDenaro is offline   Reply With Quote
Old   February 14, 2020, 16:41
"smooth problems" means that all the infinite terms (the derivatives) in the local truncation error are bounded and of unitary order of magnitude.
Old   February 14, 2020, 16:51
Raphael
What is intended by "linear scheme"?
Why would a non-linear problem be different e.g. NS equations?
Old   February 14, 2020, 16:59
Linear scheme means that the process that produces the numerical solution is based on a linear transformation, that is f= A.x. For example the stationary time integration method, like FTUS, FTCS or other, can be written as
f^n+1 = (A)^n+1 . f^0
You can make non linear a scheme also for a linear PDE.
Of course, a non linear PDE generates a non linear algebric system
discretization scheme, first order upwind, second order upwind
[ICEM] Mesh Independence study Carlos Modesto ANSYS Meshing & Geometry 4 July 7, 2017 07:57
Ahmed body 2D -Questions about mesh independence, Y plus value and others treviusss FLUENT 0 July 6, 2017 08:52
Grid Independence of Boundary Layer Luigi_ STAR-CCM+ 7 January 15, 2012 15:40
Grid Independence of Boundary layer Luigi_ Main CFD Forum 0 December 14, 2011 14:42
Need for Mesh Independence Study nickninevah Main CFD Forum 6 October 15, 2010 18:25
