In Q-criterion method, is the value of Q representative of vortex strength? |
S Banerjee
Rep Power: 7 ![]() |
It is known that connected regions of Q>0 represents vortices. Therefore can we think the magnitude of Q above 0 is representative of the vortex strength?
S Banerjee
But you are just using synonyms for the exact same wording. There is nothing mathematical or physical in that concept.
What I wanted to put forward is that, as a matter of fact, we don't have a single, clear, physical definition of what a vortex is. What we have, instead, is an ensemble of features we think should be present in what we call vortex. Q is just one of them. Quoting Lesieur: "Q>0 is a necessary condition for the existence of thin, convex low-pressure tubes [...] which are generally associated with coherent vortices". In particular, note that nothing is said on its magnitude. However, the higher is Q, the larger the local pressure Laplacian, which is a measure of the local pressure difference. |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
I think we should come back to the basic definition of vortex tube as detailed by Chorin & Marsden in their textbook. Intensity of vorticity multiplied by the area section is constant.
q criterion, turbulence, vortex, vortex detection, vorticity |
The isosurface of Vortex with Q criterion | leileiji | Tecplot | 0 | July 14, 2019 05:09 |
Induced downwash velocity for drag computation in Vortex Lattice Method (VLM) | Sehwan | Main CFD Forum | 3 | September 13, 2018 14:33 |
What's the TUI command for turning on the Vortex Method in Boundary Conditions: LES? | kingjewel1 | FLUENT | 7 | June 1, 2018 19:05 |
vortex method codes | Pengyong | Main CFD Forum | 0 | March 30, 2004 10:15 |
vortex method | Ng yow Thye | Main CFD Forum | 2 | April 10, 2000 04:05 |
