CFX torque calculations single instance vs whole domain |
December 9, 2019, 10:50 |
Rep Power: 12 |
Hi all,
I've got probably simple question to answer. I'm modeling simple rotor wheel, but not full 360 deg, just 1/5. I get the results and try to calculate torque for rotating axis X. The problem is, should I calculated torque value multiply by 5 or whether to get torque for whole rotor wheel I need run model 360 deg? My guess is, that torque for on instance should be the same like for whole domain, but it's not agree with my hand calcs. I've checked if can find help in ANSYS manual and here in other topics and FAQ, but I have not seen something like that anywhere. Please help, if you can. |
December 9, 2019, 11:40 |
Lucky
Rep Power: 66 |
Yes you do need to multiply by 5. Torque (forces) are calculated based on the domain size.
December 9, 2019, 11:46 |
Rep Power: 12 |
December 9, 2019, 15:31 |
Lucky
Rep Power: 66 |
No I don't have a paper. Who needs paper for this? And who would even write it? It's trivial.
Torque is based on moments (or force x length). Force is the surface integral of pressure acting over an area. If you have trouble with this, remember the joke of hide-n-seek where Newton draws a square meter and says that "you found Pascal!" Area goes like area, which is dependent on the area that you include in your model. That's why it goes like the domain size. If you model 1/5 of the area, you get 1/5th of the force and so on. |
cfd-post, cfx, instance, torque |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 11:38 |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 07:29 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 05:07 |
CFX 11.0 "Vector Variable Normal” Does not Rotate with Domain? User Surface Moving | jrl4444 | CFX | 4 | November 14, 2013 18:46 |
Torque calculations. | J. Keays | CFX | 21 | July 12, 2001 10:03 |
