September 23, 2019, 14:40 |
Transient Convergence
Soumitra Vadnerkar
Rep Power: 8 |
If after sometime, every subsequent timestep is converging in mere 2-3 iterations (i.e. very quickly), can we say the solution not variables are not drastically changing, meaning the solution is nearly converged already?
September 23, 2019, 14:42 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
No, the convergence to a steady state solution must be confirmed by the residuals on the equations, that is the time derivatives magnitude. |
September 23, 2019, 15:13 |
Soumitra Vadnerkar
Rep Power: 8 |
I have kept the residual criteria for all equations--continuity, velocity, energy, etc. in my transient simulation as same as they are for a typical steady-state simulation.
And with these set targets, each of the residual criteria is satisfying for every time-step within no more than 2-3 iteration calculation per time-step; and this is happening for almost all subsequent time-steps. |
September 23, 2019, 15:24 |
#4 | |
Rep Power: 73 |
If the residuals correspond to the time derivatives and the thresholds for the convergence criteria is adequate, you can assume that the computed solution is steady. |
September 24, 2019, 00:04 |
Residual plot for a transient simulation
Soumitra Vadnerkar
Rep Power: 8 |
Sorry to ask again, but, just to be clear,
Can we say about the attached image of residual plots of a transient simulation indicate that the solution is nothing but a converged steady-state solution?tube_fluid-1-01001.png In other words, is it so that, maybe if a converged steady-state solution (with same residual target criteria) was available would seem no different than this transient simulation ? |
convergence, timestep, tranient |
how to confirm convergence transient VOF ? | josephmp | FLUENT | 0 | April 26, 2015 00:40 |
Convergence Criteria for first Timestep in transient run | aerost | CFX | 3 | February 19, 2013 05:01 |
transient case diverged all of a sudden after already convergence | wc34071209 | OpenFOAM Running, Solving & CFD | 2 | November 12, 2012 07:55 |
Convergence for a transient problem | jgrisham | FLUENT | 0 | July 17, 2012 12:47 |
Transient axial rotor/stator convergence issue? | Nicola Viscanti | CFX | 3 | March 17, 2010 05:15 |
