Fully developed flow and convergance
Like Tree1Likes
  • 1 Post By flotus1
Old   September 10, 2019, 15:17
Default Fully developed flow and convergance
Soumitra Vadnerkar
soumitra2102 is on a distinguished road
What is connection between a fully developed flow and its convergence?
Can I say, in case of simple flow through pipe scenario, a converged steady state solution would always yield a fully developed flow at the outlet?
Also do you think the attached image of velocity contour can represent a fully developed flow till the time it reaches the outlet?
https://postimg.cc/Dmf1r3hb
soumitra2102 is offline   Reply With Quote
Old   September 10, 2019, 16:33
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
A converged solution does not imply fully developed flow. Flow "development" depends on flow length (i.e. distance of outlet from the inlet) and Reynolds number.
So if the computational domain is not long enough for the flow to be fully developed, you won't get a fully developed flow at the outlet, no matter how good the numerical convergence is. Unless of course you prescribed fully developed conditions at the inlet
The easy way to ensure a fully developed flow would be periodic boundary conditions.
soumitra2102 likes this.
flotus1 is offline   Reply With Quote
Old   September 11, 2019, 10:23
el_mojito is on a distinguished road
"Fully developed" is a property of a physical flow at hand while "convergence" is a property of a numerical solution. The two have literally nothing to do with each other.
el_mojito is offline   Reply With Quote
Old   September 11, 2019, 10:50
Soumitra Vadnerkar
Yeah but, I thought that as velocity profile does not change further, it might be helping for convergence.
convergance, fully developed flow, velocity profile
K Epsilon convergance issue Ollie OpenFOAM 2 April 18, 2011 09:28
Inviscid Flow Convergance issues FormulaRacer Siemens 1 November 19, 2010 15:18
Free Surface Problem - Convergance Toby FLUENT 0 July 3, 2008 00:16
Second order convergance. Rob FLUENT 2 July 20, 2004 11:49
mass convergance subhash Siemens 2 September 9, 2002 02:14
