les grid
Like Tree5Likes
  • 1 Post By Panda School
  • 1 Post By siw
  • 1 Post By FMDenaro
Old   August 14, 2019, 09:26
Default les grid
Fonzzao
Panda School is on a distinguished road
i'm new to large-eddy simulation and trying to simulate the flow around a wing section using LES. I found no clear criteria for computational grid of LES.
is there any books or papers you can recommend about this topic?
Thanks in advance,
Z.F.
Svetlana likes this.
Panda School is offline   Reply With Quote
Old   August 14, 2019, 10:22
siw
Stuart
siw will become famous soon enough
ANSYS software presentation at http://www.tfd.chalmers.se/~lada/com...4_for_Lars.pdf. See Slide 11 onwards.
siw is offline   Reply With Quote
Old   August 14, 2019, 11:11
Fonzzao
Wow, that really helps, Thanks a lot!
Old   August 14, 2019, 15:56
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Panda School View Post
Thanks in advance,
Z.F.
You cannot use LES around a 2D wing section but you need to extend the 3D spanwise direction. You can approximate a small part of the geometry using periodic conditions otherwise you need a full 3D geometry and the grid has to be very refined
FMDenaro is offline   Reply With Quote
Old   August 15, 2019, 03:53
Fonzzao
Thank FMDenaro for your reply.
I intend to extend the model in spanwise direction and apply periodic boundary conditions. But I don't know why LES cannot be used to simulate the flow around a 2D wing section. As I know, there are papers about 2D LES calculations.
Old   August 15, 2019, 04:14
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
You can of course use LES in a 2D domain. But only if your intention is to simulate 2D turbulence. Its behaviour is fundamentally different from 3D turbulence. So if the physical domain is 3D, you can not run your LES in 2D and expect correct results.
flotus1 is offline   Reply With Quote
Old   August 15, 2019, 04:19
Fonzzao
I think I got it, thank Alex for your explanation.
Old   August 15, 2019, 04:46
The issue is not in the lack in the LES formulation but in what is the aim of using LES (or also DNS). Using LES means you want to describe the physics of large vorticla structures of the turbulence as better as possible. In a 2D assumption, the vorticity dynamics is forced to have no stretching action, which is a fundamental mechanism in turbulence to create the energy cascade. Thus, you could also perform a 2D LES but the solution is not a physical description of the real turbulence.
Maybe you have read paper (I also have written some papers of 2D LES) in which LES is used for geophysical flows in a quasi-2D turbulence, that is a flow problem where two flow is developed more in the plane than in the third direction. That is not possible for a wing section.
Old   August 15, 2019, 08:32
Fonzzao
Now I know the difference between 2D and 3D LES, thank you again for your detailed explanation.
I'd like to take this opportunity to ask you whether LES is an appropriate method to analyse the wake behind a wing section at moderate Reynolds number, say, about 10e5. I know DNS could be a better choice but it is quite expensive computationally at such a Reynolds number.
Old   August 15, 2019, 11:18
A pure (wall resolved) LES around a 3d wing section will be computational expensive almost as much as a DNS ... Generally, this flow problem is solved using DES
Old   August 15, 2019, 22:36
Fonzzao
Thank you for your answer and patience.
Old   August 16, 2019, 03:58
If you are interested in a deeper understanding of the LES topics, you could have a read to my lectures about LES and the references addressed there
https://www.researchgate.net/publica..._Part_I_and_II
dyle likes this.
les grid
What is the difference between Non-staggered and Collocated grid? carl jung Main CFD Forum 2 January 23, 2017 15:39
How to determine the grid size in LES lin OpenFOAM Running, Solving & CFD 0 April 28, 2010 22:55
LES on unstructured grid in fluent Zafer Zeren FLUENT 0 December 20, 2005 07:45
grid about LES and RANS bjcz Main CFD Forum 5 April 22, 2002 12:42
LES & grid quality Ales Skotak Main CFD Forum 1 July 23, 1999 10:46
