Calculate derivatives in a non-uniform grid |
August 1, 2019, 07:08 |
Rep Power: 8 |
I have a non-uniform 2D grid (non-equal intervals between nodes). [x,y]
I also have the data (U) calculated on this grid. I want to calculate the derivatives of U with respect to y and then x. How can I do this? (Specially using MATLAB) |
August 1, 2019, 07:17 |
Svetlana Tkachenko
Rep Power: 14 |
Is it rectangular grid?
You could just use matrix operations ie dmyfdx = (myf(2:end)-myf(1:end-1)) / (coordx(2:end)-coordx(1:end-1)) where myf is your variable and coordx is the x coordinate in the grid. If this is not sufficiently helpful then please create a small test case demonstrating the data format in a small example. Thanks. |
August 1, 2019, 07:45 |
#3 | |
Rep Power: 8 |
August 1, 2019, 17:17 |
Svetlana Tkachenko
Rep Power: 14 |
I think you can view the formulas here
http://web.media.mit.edu/~crtaylor/calculator.html Vary the number of input points to get the desired order of accuracy. |
August 1, 2019, 17:39 |
#5 | |
Filippo Maria Denaro
Rep Power: 73 |
For example, you have the value f1,f2,f3 at x1,x2,x3. Then you can define a lagrangian second degree polynomial and compute analytically the derivative. More nodes allow you to increase the degree of the polynomial and the accuracy of the derivative. Have also a look to the textbook of Peric & Ferziger |
August 2, 2019, 01:23 |
#6 | |
Rep Power: 8 |
derivatives, non-uniform grid |
dsmcFoam setup | hherbol | OpenFOAM Pre-Processing | 1 | November 19, 2021 01:52 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
LES supersonic free jet | martyn88 | OpenFOAM | 22 | April 17, 2015 06:00 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 02:54 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
