July 15, 2019, 09:25 |
Governing equations vs Transport equations
Mandeep Shetty
Rep Power: 10 |
This is a basic question. But I did not find any explanations for this. How are governing equations, like mass, momentum, energy conservations equations, different from 'Transport equation'?. Is a conservation equation, like energy equation (heat equation), a transport equation for the temperature?
July 15, 2019, 10:49 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Transport equation is a general denomination for the advection-diffusion PDE, see https://en.wikipedia.org/wiki/Convec...usion_equation The equation is not necessarily related to a flow problem, for example they are often referred as to the transport of chemical species (advecion velocity prescribed). On the other hand, when we use the conservative form of mass, momentum and total energy we could see those as a more complex expression of the simple advection-diffusion equation. Do not worry if you read in literature some discrepancy |
July 15, 2019, 11:19 |
Lucky
Rep Power: 66 |
The mass, momentum, and energy equations (and many others) in CFD are indeed transport equations. The heat equation is a transport equation for the internal energy (or enthalpy depending on formulation) and an equation of state is usually invoked to write in with temperature as the primitive variable.
In general (widespread in non-fluids fields), a governing equation need not be a transport equation and a transport equation need not be a governing equation. A governing equation need not be a conservation either (economics, the stock market, etc...). In fluids, the main governing equations that you play with just happen to be transport equations based on the principles of mass, momentum, and energy conservation laws and they all are referring to the same thing. |
governing equations, navier stokes equation, transport equation |
Governing equations from physics models | AlanLJ | STAR-CCM+ | 1 | January 2, 2016 15:47 |
kEpsilon and pisoFoam: when transport equations for k and eps are solved | LuisAlberto | OpenFOAM Programming & Development | 5 | August 24, 2015 06:33 |
Solving N (Non-Coupled) Scalar Transport Equations | joel.lehikoinen | OpenFOAM Programming & Development | 9 | October 3, 2013 09:00 |
Scalar Transport Equations | David harvey | FLUENT | 1 | January 31, 2004 07:15 |
Scalar Transport Equations | 123 | Main CFD Forum | 6 | August 10, 1998 10:05 |
