Dimensions of a CFD computational domain
Like Tree1Likes
  • 1 Post By samiahmed
Old   July 8, 2019, 19:04
Default Dimensions of a CFD computational domain
samiahmed is on a distinguished road
I have a question about the dimensions of the computational domain in a CFD simulation.
I want to compare the results of a CFD simulation with an experiment done in a wind tunnel where the test section is (2m 1m x 1.5m) but now I cannot proceed further before creating my computational domain.
My question is very simple, in general when we want to compare the results with experiments (wind tunnel) do I have to use the same dimensions of the experimental setup for my computational domain? or do I have to conduct a parametric study to determine the proper dimensions of my CFD simulation?
I hope my question is clear
fredericgaillard likes this.
samiahmed is offline   Reply With Quote
Old   July 9, 2019, 04:24
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
First of all, you should compute the Reynolds number and using the same value in your CFD simulation. Then, the boundary conditions should reply the experiment.
FMDenaro is offline   Reply With Quote
Old   July 9, 2019, 05:33
I want to reproduce the results of the experiment numerically for the full scale geometry.
The test section of the wind tunnel is (2m x 1m x 1.5m). The chord of the airfoil is 0.05m.
The velocity and other parameters are known (Thus Reynolds number ...etc are known for the experiment). my question is: my computational domain should be (2m x1m x1.5) like the test section of the wind tunnel. Or do I have to use large dimensions for my computational domain
Thanks
Old   July 9, 2019, 09:43
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
It depends, most of the times experimental results are already presented with all the due corrections to be actually representative of reality. Yet, there might be ambiguities as in my sentence itself (like, what's reality in the first place?).
In this case (data with all due corrections), you should try to replicate the conditions that the experiment was trying to replicate.
My favourite route, however, is typically the opposite, but it is only possible if you have the raw data from the experiment (i.e., no corrections for the tunnel blockage, etc.). In this case you try to exactly replicate the experiment, inlcuding the test section, etc.
In more general terms it kind of depends from the reason you want to compare to experiment and, of course, from the kind of data you have available, as you might not actually have a choice.
CFD practitioners typically rely on well known experimental databases (i.e., ERCOFTAC) which are specifically compiled for the comparison with CFD, so you find all the details on how you should actually perform your simulation.
Expect troubles if the data you are using were not meant to support CFD validation. Otherwise, it is typically clear from the experiment description what you have to do to actually simulate it. In some cases you might be able to infer the correct strategy, but that's not always the case.
The very point here is how much you know about the domain where your computation is going to be performed and the relative boundary conditions. It is the experiment description that should be clear on this. If it is not than it is not validation material for CFD.
sbaffini is offline   Reply With Quote
Periodic Pressure drop cfd_begin CFX 10 May 25, 2017 08:09
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Gruber computational domain k.anand Main CFD Forum 0 April 30, 2011 03:07
Relation between CFD and computational chemistry Marc Segovia Main CFD Forum 3 May 26, 1999 06:13
