Ideal Gas vs Constant Density Solving
Like Tree2Likes
  • 1 Post By sbaffini
Old   July 3, 2019, 23:58
Smile Ideal Gas vs Constant Density Solving
Sebastian Pelletier
spelletier is on a distinguished road
Hello all!
I have a quick question regarding the effects of using the ideal gas law vs constant density solvers.
From what I understand it is recommended to use the ideal gas law for flows above ~mach > 0.3 to assure accurate results and generally below that value the compressibility effects are negligible. If however you were to use the ideal gas law for low mach number flows or flows that could be considered incompressible are you producing incorrect results? If I am not sure whether my flow is effected by compressibility is it more safe to use the ideal gas law or to leave a constant/incompressible density?
spelletier is offline   Reply With Quote
Old   July 4, 2019, 04:27
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
If the method you are using is capable of handling the intricacies of a compressible fluid model (as ideal gas is) working in the low Mach regime, then you are fine, at worst you are wasting some computational resources.
spelletier likes this.
sbaffini is offline   Reply With Quote
Old   July 4, 2019, 04:29
sbaffini's Avatar
Paolo Lampitella
For example, the solvers in Fluent are all capable of this, so no worry if you are using it. Still, some specific knowledge is required to properly use such solvers.
compressbility effects, density, ideal gas law
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
