Is pressure a harmonic function in ideal fluid flow ?
Like Tree1Likes
  • 1 Post By sbaffini
Old   June 3, 2019, 16:17
Default Is pressure a harmonic function in ideal fluid flow ?
sam
mczero57 is on a distinguished road
For an incompressible, irrotational flow in three dimensions, does the pressure satisfy Laplace's equation ? I know the velocity potential does. What about the pressure field itself ?
Thanks
mczero57 is offline   Reply With Quote
Old   June 3, 2019, 16:46
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thanks
Take the divergence of the momentum equation and see what happens
FMDenaro is offline   Reply With Quote
Old   June 3, 2019, 19:24
sam
Filippo,
Thanks.
Thinking about it some more, the answer has to be - not in general. We can show this by counterexample - take the point source which has the potential 1/r. Its velocity field is 1/r^2. Since p + 1/2 rho v^2 = constant, its pressure field is thus 1/r^4 which is not harmonic.
Old   June 4, 2019, 03:34
Indeed pressure obeys a Poisson not a Laplace equazioni
However, that is not the real pressure in thermodynamics meaning
Old   June 4, 2019, 06:33
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
For inviscid, steady, irrotational flows it is the total pressure, static + dynamic, that obeys a laplace equation
FMDenaro likes this.
sbaffini is offline   Reply With Quote
Old   June 4, 2019, 07:15
Actually some specific conditions could be possibile, for example a total pressure constant only along the streamline but changing from streamline to streamline if the flow has not upward homogenous conditions. Then the total pressure could not have a vanishing laplacian, isn’t that?
Old   June 4, 2019, 14:00
sam
Paolo,
For inviscid, steady, incompressible, irrotational flows, the total pressure p +1/2 rho v^2 is spatially constant. So, it satisfies Laplace's equation trivially.
Thanks
Sam.
Old   June 4, 2019, 14:08
Paolo,
Thanks
Sam.
homogeneous in space provided that the upward conditions are homogeneous in space... the total pressure is integrated along a streamline, but could change from a streamline to a different streamline
Old   June 4, 2019, 14:40
sam
If the flow is irrotational everywhere, the total pressure is a constant. You are thinking of the case where there is vorticity, in which case it is constant along a streamline.
Old   June 4, 2019, 14:52
Yes, of course one of the hypotheses in Bernoulli is the irrotational flow constraint. Removing this constraint is possible in the general Crocco relation from which you can deduce the laplacian of the pressure.
However, the general answer is that that the pressure equation for irrotational, inviscid, incompressible flow is
Lap p =-rho*(Lap |v|^2/2 + Lap psi)
psi being the gravitational potential function
ideal fluid
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 01:11
