May 27, 2019, 12:35 |
spectrum tensor in inhomogeneous turbulence
luca mirtanini
Rep Power: 8 |
Hi all,
I am trying to write the theory of the energy spectrum for a generic inhomogeneous turbulence. I used as a basis for my work the tennekes and lumley book. I attached here the page of this book and I tried to rewrite the spectrum tensor for inhomogeneous turbulence. Can someone confirm that I did it well? My doubt is the fact that in the exp() there is no x vector and I am wandering if I am missing something. I really hope that someone can help me |
May 29, 2019, 16:08 |
#2 | |
Santiago Lopez Castano
Rep Power: 15 |
May 30, 2019, 04:51 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
I am not sure of what exactly want to do. If you consider a fully 3d non-homogenous non-isotropic turbulence, it could be also questioned how do you define the Fourier analysis since it is not a periodic function. From the general definition you wrote, there is more that the fact your function depends on the position x. The problem is also in the extension of the integrals. I can say that in a practical case like the flow in a plane channel, where we have two homogeneous dimensions and one (normal to the wall) non-homogeneous dimension, we perform the 1D spectra along the directions of homogeneity. And these spectra are evaluated for several positions along the non-homogenous direction. |
May 30, 2019, 11:48 |
#4 | |
luca mirtanini
Rep Power: 8 |
I will not use this formula directly in a calculation. I was trying to generalize the demonstration fora a 3d inhomogeneous turbulence. |
May 30, 2019, 11:56 |
#5 | ||
luca mirtanini
Rep Power: 8 |
May 30, 2019, 12:16 |
Rep Power: 73 |
May 30, 2019, 12:30 |
#7 | |
luca mirtanini
Rep Power: 8 |
May 30, 2019, 12:38 |
Rep Power: 73 |
May 30, 2019, 12:41 |
#9 |
luca mirtanini
Rep Power: 8 |
Yes, but it should have been placed also in the 1.7. Isn't it?
May 30, 2019, 12:47 |
#10 | |
Rep Power: 73 |
No, correlation and spectra are a Fourier pair transform, for example here you see the factor in the spectra but not in the correlation https://www.google.com/url?sa=t&rct=...VEGq8lnm20jOIu |
May 30, 2019, 12:54 |
#11 | |
luca mirtanini
Rep Power: 8 |
No, if you look at the page of the tenneke and lumley book that I have shown in the first post. You can see that the psi in the paper is the phi in the book of lumley, and the Cij in the paper is the Rij in the book of Lumley. So the (1/2pi)^3 is missing |
May 30, 2019, 14:16 |
#12 | |
Lucky
Rep Power: 66 |
They have different definitions for the Fourier transform and that's why you see the 2pi in different places. Or am I misunderstanding the question? |
May 30, 2019, 16:41 |
#13 |
luca mirtanini
Rep Power: 8 |
Sorry for the stupid question, what does it means that they have different definitions for the F T? Which definition of FT is used by Trevino and which one is used by Lumley and Tennekes?
May 31, 2019, 11:15 |
#14 |
Lucky
Rep Power: 66 |
Lumley is using the one with the 1/(2pi) and Trevino is using the one with 1 as the prefactor.
May 31, 2019, 12:02 |
#15 |
luca mirtanini
Rep Power: 8 |
May 31, 2019, 13:49 |
#16 | |
Rep Power: 73 |
Have a look to pag 220 of the Pope's textbook, you see the factor (2pi)^3 in the spectrum but not in the correlation. They constitute a Fourier transform pair. The Fourier transform has the factor 2*pi, the inverse transform has not, see Appendix A (pag 678). You will read the explicit statement about the fact that this factor is sometimes interchanged between direct and inverse transform. Let me say that I often observed similar notations that drive people to some misleading reading, for example the Fourier decomposition in components along wavenumbers k=n*2pi/L where L is the length of periodicity. When sometimes is assumed L=2*pi, the factor 2*pi disappears and k=n. But n is the wavenumber while k is the dimensional frequency. |
June 1, 2019, 06:33 |
#17 | |
luca mirtanini
Rep Power: 8 |
how to set URANS turbulence model in unsteady flow simulation | TimLiu | OpenFOAM Pre-Processing | 0 | April 25, 2017 09:52 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 15:18 |
turbulence spectrum | niaz | Main CFD Forum | 0 | February 28, 2012 02:04 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 05:24 |
