May 23, 2019, 12:03 |
Turbulent boundary layer: region names
CFD USER
Rep Power: 7 |
In the context of a turbulent boundary layer, I see the following names:
(1): viscous sublayer, buffer layer, logarithmic layer (2): Inner region, overlap region, and outer region My question is: I cannot understand what is the relation between (1) and (2)!! (My guess is: the inner region is the viscous layer, the overlap region is the buffer layer, and the outer region is the logarithmic layer) Is this correct? If they are the same, there are many terms? Thanks |
May 23, 2019, 12:12 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
https://www.google.com/search?q=visc...RnonCjN8pja0M: |
May 23, 2019, 12:30 |
CFD USER
Rep Power: 7 |
Thank you
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 09:26 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
