Flow time?
Like Tree6Likes
  • 1 Post By FMDenaro
  • 1 Post By LuckyTran
  • 2 Post By FMDenaro
Old   May 1, 2019, 06:38
Default Flow time?
Michael Fily
bietchetlien1995 is on a distinguished road
Hi all!
I do the analysis of flow over a building.
The inlet constant velocity at 30m/s.
My domain has size of 1000x1000x4000 m, and distance from inlet to building is 1000.
I use LES model to analysis with the turbulence properties at default (Synthetic Turbulence Generator)
After 30,000 of iterations using the Adaptive Time Method,
It showed me at console "time flow" = 1.49.....s
I wanna ask is it a "real time" flow?
And when I check the result: the velocity and also pressure on my building were balance.
But, how can after near 1.5 second, how can it make pressure on the building when it just came (30m x 1,5s).?
OR I got wrong about flow time?
Pls help me, thank so much
https://www.cfd-online.com/Forums/at...1&d=1556703480
bietchetlien1995 is offline   Reply With Quote
Old   May 1, 2019, 07:34
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
If the flow is modelled as incompressible, the fluid moves istantaneouysly everywhere.
bietchetlien1995 likes this.
FMDenaro is offline   Reply With Quote
Old   May 1, 2019, 13:48
Lucky
The flow time is like the time on your clock.
Pressure waves travel at the sound speed so there is a force at a distance.
Old   May 1, 2019, 21:39
Michael Fily
So. If I want to capture the pressure acting on the building. I just need to see the balance in results and stop or any suitable time for guarantee the results will not change any more.
Thank you so much for all replies
Old   May 2, 2019, 04:16
It is not so simple... In LES you need to run the code for a quite long time, until the initial condition is disregardeble and the flow statistics are fully developed. Only after that, you can collect the fields over a period of time and performing the average.
bietchetlien1995 and Sakun like this.
Old   May 2, 2019, 04:21
Michael Fily
for example, if my initial velocity at inlet is 25m/s, so, when the outlet (outflow) have value around 25 or more (maybe less).
is this that time, the flow will be fully developed?
Thank you for your answering
Old   May 2, 2019, 04:37
No. You need to check the global field. For example compute the total kinetic energy in the domain and check it along the time. When you get a period where it oscillates in time across a constant averaged value you have a fully developed solution. Only after that the LES is physically relevant.
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
