CFD Thesis
Like Tree6Likes
  • 1 Post By asda3D
  • 1 Post By praphul
  • 1 Post By asda3D
  • 2 Post By LuckyTran
  • 1 Post By Svetlana
Old   April 24, 2019, 08:10
Default CFD Thesis
anonymous
asda3D is on a distinguished road
Hi everyone I am currently writing up a thesis due in just under 2 months.
I am writing up my mesh sensitivity study that I have conducted. I am unsure if I should put this in my results and discussion section or if I should put it in my CFD setup section (included simplifying RANS, creating geometry and generating mesh through y plus).
Any recommendations much appreciated
Svetlana likes this.
asda3D is offline   Reply With Quote
Old   April 24, 2019, 10:05
Praphul T
praphul is on a distinguished road
It's better to put the mesh sensitivity study at CFD setup section. You can also mention about grid independence study (1-2 sentences) in the preamble of the result section that the results were taken for the optimum grid as found from mesh sensitivity study.
praphul is offline   Reply With Quote
Old   April 24, 2019, 10:28
anonymous
Thank you praphul
I will take on board what you said
praphul likes this.
Old   April 24, 2019, 13:29
Lucky
There's really no such thing as grid independence, only grid sensitivity. Your grid sensitivity is a very important metric. It's analogous to your experimental uncertainty.
Would you report the uncertainty of a derived result while describing how you recorded measurements? Not usually...
Svetlana and bhanuday.sharma like this.
LuckyTran is online now   Reply With Quote
Old   April 24, 2019, 20:24
Svetlana Tkachenko
Svetlana is on a distinguished road
This could go to a separate verification & validation section if you like as well, or a subsection like that in the results section. I would suggest to check other CFD theses at your university, they can be available in the library in electronic format.
For mesh sensitivity I would suggest looking at "H-convergence plot" and "Grid Convergence Index" if you have not done so already.
Pravaah likes this.
Svetlana is offline   Reply With Quote
Old   April 25, 2019, 03:03
anonymous
Thank you for that!!!
I will access the library to see which layouts have been used in previous theses
Old   April 25, 2019, 05:58
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
This part should be organized in the results section. Depending on the type of solution, a grid can be refined to explore the order of accuracy (if you have an analytical solution) or to explore the independence of the solution after a certain grid resolution is reached. If you are solving modelled equation for turbulence that could be further extended to address the sensitivity of the model.
You should provide more details to understand the topic you have to write
FMDenaro is offline   Reply With Quote
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 September 13, 2000 05:48
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 05:49
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 16:01
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
