LES question: Why must the eddy viscosity be rotation-invariant?
Like Tree1Likes
  • 1 Post By sbaffini
Old   April 12, 2019, 13:44
Default LES question: Why must the eddy viscosity be rotation-invariant?
ulfu is on a distinguished road
hello all,
I am a new beginner in LES and CFD. I am reading all I can on LES modelling, but I think I am missing something. All the papers and books state that for eddy viscosity models, the eddy viscosity must be rotation invariant. That means that we have to use the same eddy viscosity for the u,v, and w equations, correct?
Why is that the case? I understand that the physical viscosity is a scalar, so rotation invariant. However, the eddy viscosity is a pure model term, not physical. Why can we not use different eddy viscosities in different equations? For example, in the wall normal direction, why can it not be different from the wall parallel directions? This has me very confused! Does anybody know? Are there any models with different eddy viscosities?
thank you all
greeting
ulfu
ulfu is offline   Reply With Quote
Old   April 13, 2019, 19:52
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Originally Posted by ulfu View Post
hello all,
thank you all
greeting
ulfu
There are indeed anisotropic eddy viscosity models, where the eddy viscosity is a 4th order tensor in general. Check the Sagaut book for an account of such models.
What rotation invariance refers to is the fact that the eddy viscosity, as a function of the resolved velocity field, cannot depend from the frame of reference, including its rotation.
FMDenaro likes this.
sbaffini is offline   Reply With Quote
Old   April 14, 2019, 17:19
TurbJet is on a distinguished road
Historically, eddy-viscosity stems from Boussinesq hypothesis, which is analogous to Newton's linear stress-rate-of-strain relation, where the shear stress is proportional to the strain rate with the physical viscosity, and it is isotropic as you point out since it's a scalar. The eddy-viscosity pretty much follow the same way.
TurbJet is offline   Reply With Quote
Old   April 14, 2019, 17:40
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I think that there is a motivation in the hystorical assumption of the fully developed turbulence. For transitional flows there were DNS studies that showed that anisotropy exists.
However, there is not a definite assessment that anisotropic SGS eddy viscosity models perform better than classical models
FMDenaro is online now   Reply With Quote
Old   April 15, 2019, 12:50
Thank you for your answer, I will check the book and learn about the models. I am still not sure I get what rotational invariance means, though. Is it the same as isotropy, or do these concepts differ?
Also, I am trying to combine the two issues you mentioned in my head but I fail:
1) Anisotropic models exist
2) the eddy visocity cannot depend on the frame of reference.
Is 1 not a contradiction of 2?
Let us say we are considering a boundary layer, where x is the streamwise direction and y is normal to the wall. A reasonable eddy viscosity could now be constant in x, but e.g. have y ^ 3 towards the wall - is this not a a contradiction of rotational invariance? I am sorry if this is stupid, but I cannot find the solution.
Thanks a lot
ulfu
Old   April 15, 2019, 12:52
so Professor does this mean that we could have 3 different eddy viscosities, for each direction? Or does the viscosity have to be a tensor?
Old   April 15, 2019, 19:04
Lucky
This is a non-homogeneous mapping, but is almost guaranteed to be an isotropic eddy viscosity. A function of x,y,z that spits out a single scalar value for the eddy viscosity means that it's still a rank 0 tensor which is always isotropic and always has rotational invariance (a scalar is a scalar).
Isotropic tensors have rotational invariance by definition.
In general the anisotropic eddy viscosity is a 3x3x3x3 fourth order tensor. The eddy viscosity maps a tensor (the velocity gradient) onto a tensor (the Reynolds stresses). There aren't 3 directions but actually a bunch of dyadic directions. An anisotropic physical diffusion coefficient is often considered as having 3 directions because it maps a vector (the scalar gradient) onto a vector (the flux vector). But you are on the right track.... If there is directionality to this mapping, then it could be anisotropic.
Actually physical viscosity can also be generalized to an anisotropic tensor. The requirement that the eddy viscosity is rotationally invariant is historical, where it is normally treated as a scalar. But no matter how complicated your function, if your physical or eddy viscosity comes out to be a scalar then it is rotationally invariant.
Old   April 15, 2019, 21:50
sbaffini's Avatar
Paolo Lampitella
They are two completely different concepts.
Assume you have a certain reference frame, a velocity field and the resulting anisotropic eddy viscosity model, which has a certain action on it.
Now, rotation invariance means that, if you just change the reference frame, all else being equal, your model action can't change.
For scalar eddy viscosities it is, I guess, obvious.
For anisotropic ones it means, for example, that the action on the wall normal direction is independent from it being along x, y, z or any combination of them.
Old   April 16, 2019, 04:09
The key is that the eddy viscosity should be seen as a tensor M_eddy. This way, in matrix notation, you could suppose to find the eigenvalue and express the tensor in the main system as a diagonal matrix having the eigenvalues along the main entries. Invariance to rotation is the assumption that the matrix is diagonal in any system of reference and reduce to nothing else that eddy_viscosity*I. Therefore a single value along each direction is supposed to exist.
Eddy viscosity VS Turbulent viscosity Shayankhan FLUENT 8 May 2, 2021 10:00
Erroneous eddy viscosity ratio for pipe flow preis OpenFOAM Running, Solving & CFD 1 May 11, 2018 20:58
Molecular viscosity calculation in LES on OpenFOAM babakflame OpenFOAM 0 January 26, 2014 05:13
question for LES colopolo Main CFD Forum 12 March 23, 2009 10:54
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow harishg OpenFOAM Bugs 5 December 2, 2008 19:18
